TIME SLIP DATABASE
Finally in the 11s
Old Jul 25, 2015 | 05:50 PM
1979rs/z28's Avatar
12 Second Club
Ive been tuning it, tried everything from shift times to adding torque management on the shifts with no luck. It has seemed to get a lot worse with the added power (boost increase) i put a post in the tuning section describing it just to make sure ive covered all the bases. Pretty sure its 80e time!
Old Jul 25, 2015 | 05:51 PM
GMCtrk's Avatar
What is the shift command rpm at
Old Jul 25, 2015 | 05:52 PM
1979rs/z28's Avatar
12 Second Club
Right now its at 5900. We've had it as low as 5000 also, it commands the shift it just free revs when it does
Old Jul 25, 2015 | 05:58 PM
GMCtrk's Avatar
The trans is doing something then. Is the trans built?
my shift is set to 4400 rpm
Old Jul 25, 2015 | 06:01 PM
1979rs/z28's Avatar
12 Second Club
I've thought about lowering down to 4-4500 just for the hell of it to see what happens. The trans builder thinks the 3-4 band maybe starting to wear. It is built
Old Jul 25, 2015 | 06:02 PM
GMCtrk's Avatar
Lower it down and see if it works. The more power, the lower the shift needed.
Old Jul 25, 2015 | 06:05 PM
1979rs/z28's Avatar
12 Second Club
What kind of shift times you running?
Old Jul 25, 2015 | 07:01 PM
fastjweb's Avatar
It's weird, because once it shifts, it holds the power fine.
Old Jul 25, 2015 | 07:20 PM
03sierraslt's Avatar
Keep your shift times above .250
Old Aug 15, 2015 | 05:23 AM
03chevytruck's Avatar
Congrats on the run. I can't wait to see how she does when all the kinks are fixed!! I hope mines runs as well as yours when it finished.
