Drag Wheel/tire to fit over disk brakes.
Does anyone make a off the shelf 17" wheel that is wider than 10" for those M&H 390 tires that won't have them sticking way out the wheel wells. I've looked on the internet but haven't found anything. It seems like every wheel I find only has 4-5" backspacing.
I know you can mount them on some racestars but at only 9.5 inches wide I'm sure it would be less than ideal. M&H recommends a 12" wide wheel.
https://www.performancetrucks.net/fo...estars-532356/
That 9.5" might be good for you, I have a 4/6 drop on my truck and with my previous tire which was a 305/45/18 on a 18x8Wheel it rubbed on my fender quite a bit. I'm thinking with a 29.5 tire and a 12" rim you may be getting awfully close to doing the same. The smaller the rim the less tread width there is and that could help you out in this instance for clearing. I just tried to get a 29x11x15 Hoosier slick on a 10" wide rim out back and it wouldn't fit due to the leaf springs ( learning moment for me) but I didn't even get a chance to try and lower it on the 29" tall tire to see the clearance but I know from what I saw it was awfully close.
Hope this can help some
Check out my pic in the build thread. Those are 390 M&H's on 17" Racestars on a 4/6 drop - I borrowed them from Fastjweb for a picture. They clear the leaf spring by about 2 inches, but could possibly require some fender trimming/rolling depending on how much suspension travel you have: https://www.performancetrucks.net/fo...513440/page13/
GXPJAY
Feb 13, 2022 08:15 AM
Superman09
Sep 25, 2015 05:55 AM
