TIME SLIP DATABASE
4.8L Quarter Mile Estimate
Old Apr 10, 2015 | 11:12 AM
lycominghunter's Avatar
Default 4.8L Quarter Mile Estimate
If the weather holds, I'll be headed to the track tonight. Haven't been in over a year, and I was wondering what y'all thought my 2003 4.8l rcsb sierra with a 4/6 drop will run (mods below).
LS1 Fans, Holley Hi-ram, 90mm throttle body, Isky triple 12, 3400 stall, vette servo, Assassin bars, relocated QA1 single adjustables, ET Streets, 3.42 gears, 93 SD Tune.
Last year it ran a 14.39 at 96mph with a 2.2sec 60ft on street tires. Since then I have done the Hi-Ram, 90mm throttle body, shock relocation. Just curious as to what I can expect. Will post up results when I get them. Thanks!
Old Apr 10, 2015 | 10:35 PM
JoeyGC5's Avatar
Any results?
Old Apr 10, 2015 | 10:54 PM
thewrx's Avatar
Why put a hiram on that small of n/a motor? That has got to be killing your low end.
Old Apr 11, 2015 | 09:53 AM
10 Second Club
Same thing I was thinking... but maybe he's putting a turbo on it in the future? Even still... seems overkill for a cam only 4.8L
Old Apr 11, 2015 | 11:46 PM
HATERZ! HAHA however y'all might be onto something. It was pretty awful weather last night for racing given the humidity. My mph was there but looking through the logs quickly it appears that my low end is suffering. Ended up running a 14.8 at 95, so pretty disappointing night. I ran the 14.39 in dry, 50 degree air. Have to go back and check the DA to compare. Also, I was only able to cut 2.2 60fts (never used drag radials before so I had the psi too high).
The reason I went with the hi-ram was I'd rather spend the money now and do it once, rather than spending more money and redoing different parts of the build as I progress. So, I did the hi-ram, 124lb injectors, -8an feed and -6 return, and walboro 450 - definitely overkill for a cam only 4.8l but I should be set for a while. My 76mm kit arrived today, and I'll only be running this 4.8l as long as it lasts and then I'll build the lq9 block I have.
I really wanted to be able to cut a good 60ft and run in some cooler weather in hopes of getting a mid 13 second pass with a N/A 4.8l, which I don't even know if that would be a good or bad time given the mods I've done, but we might be too close to summer for dry, cool air here in NC. Oh well, its an experiment. Maybe next week I'll have some better times.
J
Old Apr 12, 2015 | 07:22 PM
10 Second Club
Not hating, figured you had bigger plans.
pjb1972
Sep 17, 2015 02:06 PM
Verz
Aug 21, 2015 06:40 PM
black00chev
Aug 12, 2015 01:56 PM
dantheman1540
Jul 29, 2015 04:45 PM
Ketis
Jul 23, 2015 12:37 PM
