TIME SLIP DATABASE
Couple clips from Sundays 8th.
Old Apr 18, 2012 | 08:09 PM
foose04's Avatar
I currently have stock 862's. Would it be worth the swap, maybe. We'll see how things go, but they may end up on this year if I want to start pushing closer to 25psi.
Their info:
Combustion Chamber Volume: 61.15cc
Compression Ratio: 9.5:1
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 1.89 inches
Exhaust Valve Diameter: 1.55 inches
Stock Head Flow Numbers
Chamber 61.15 cc----0.100--0.200--0.300-- 0.400--0.500---0.550---0.600
Intake 200 cc----------63 ---128----179-----210----218----221-----226
Exhaust 70 cc----------54 -- 93 ----121----145-----163----168----174
My 317's are cleaned up to 69cc.
Combustion Chamber Volume: 71.06cc
Compression Ratio: 10:1 LQ9 Flat top pistons
Compression Ratio: 9.6:1 LQ4 Dish piston
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Intake Valve Diameter: 2.00 inches
Chamber 71.06cc----0.100---0.200--0.300--0.400--0.500--0.550--0.600
Intake 210cc-----------66-----142-----196---228----236---238-----240
Exhaust 75cc----------59-----104-----137---155----167---173-----177
Old Apr 18, 2012 | 08:21 PM
foose04's Avatar
Originally Posted by SCTUNDRA
What stall are you running.
It's a circle D, multi-disc, 2b stall. 28-3000.
Old Apr 18, 2012 | 10:04 PM
Jake99's Avatar
Nice race with the stang! you think going with such bigger chambers would be an advantage? If I ever get mine pushed as hard as yours I had planned on a milled ls6 head, that way I get a little bigger runner, bigger intake valve and match the stock 9.5 cr. Might work out good when you spraying n20 throw it tho.
Old Apr 18, 2012 | 11:10 PM
smokeshow's Avatar
Mod with training wheels
You'd lose a considerable amount of compression with those heads, as I'm sure you know. May not even be worth it.
Old Apr 18, 2012 | 11:31 PM
foose04's Avatar
Yeah but with some timing room of E85 and larger chamber to welcome airflow volume, plus the valves/ports, I think it would be ok.
My hold up is I can bottle feed it or boost it to where I think the internals will give before the added head HP is even really needed.
Old Apr 18, 2012 | 11:39 PM
smokeshow's Avatar
In that case, I know someone who would be interested in those heads lol
AdaMax
May 16, 2016 11:35 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
Infernohoe
48
Oct 2, 2015 10:25 PM
The_W
Oct 1, 2015 02:35 PM
old motorhead
Sep 29, 2015 08:22 PM
