TIME SLIP DATABASE
Couldn't get it done. No PB.
Old Nov 8, 2014 | 10:14 AM
TXsilverado's Avatar
what tire are you running out back?
Old Nov 8, 2014 | 10:17 AM
nevermind. see it in your sig. for some reason I was thinking you were on a drag radial. I was going to say you're running too low of tire pressure but nevermind.
Old Nov 8, 2014 | 12:01 PM
GMCtrk's Avatar
I am on a drag radial. MT recommends 12-16 psi for these tires.
Old Nov 8, 2014 | 12:19 PM
I run 18 lbs on the 275/60-15. not sure if the 315 is that much different. don't be afraid to try more on a radial. if 13-15 doesnt work for you, try 17.5 psi...if it 60' better keep going up on the pressure 1/2 psi at a time until it slows down again. you want to run the most psi that you can consistently hook.
Old Nov 8, 2014 | 03:18 PM
oakley6575's Avatar
Thank you for changing your sig pic.
Old Nov 9, 2014 | 08:30 AM
vicalma03's Avatar
Nice runs. Like mentioned above a better sixty should net you 10s!
Old Nov 9, 2014 | 12:23 PM
Vortec350ss's Avatar
Baby steps... youre getting it dialed in one step at a time. Its nice to see it improving with each pass.
Old Nov 9, 2014 | 12:50 PM
GMCtrk's Avatar
Yeah, the 275s and 315s are in different classes as far as tire pressures go, per MT. When I dead hooked on the 11.1 run I had 15 psi in the tires. Most posts I've come across from people running this tire, they run between 15-16 psi. However, those are in small, light cars. I'm near 5000 lbs so a little less tire pressure may be needed.
Old Nov 9, 2014 | 04:31 PM
fastjweb's Avatar
i had 30 psi in the M&Hs on my 1.69 60ft. thats a non boost lauch though. I tried to leave harder but they spun also.
SloSVO
Nov 22, 2020 07:34 PM
Tydriver
45
Oct 23, 2015 09:19 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
screaminian47
Sep 7, 2015 08:20 PM
mayko
Sep 7, 2015 12:24 PM
