Casper sets the bar once again on a 5.3L
#65
Here is the list of what's been done to my truck and everything was done at my shop. Im running 16 pounds of boost now and a 75 shot. I eather use meth or nitrous but not both at the same time. I have'nt been able to make it hook with the nitrous off the line so i spray after the 60 foot.
2008 chevy silverado 5.3L
tuning
All tuning done by me
motor
5.3L with 243 heads from factory "untouched"
custom XMS cam 224-222 581-581 lsa ?"i'll pm it to you if needed"
comp cams 7.400 push rods
comp cams 26918 springs
ASP crank pulley
custom MSD wires
NGK spark plugs
XMS custom BY NORIBILT front mount turbo kit. modified 76GTS turbo
twin front mount air to air intercoolers
3 inch down pipe with race magnaflow muffler and stock tail pipe no cut off
meth kit
TNT F-1 kit 75 shot
Throttle body spacer
160 stat
Fuel system
Dual walbro intank fuel system
Aeromotive boost ref. fuel regulator
stock fuel rails but modified to convert to retune fuel system
steel braided #6 line from tank to rails and returne to tank with #6 an
SVO 42# injectors
Fast ev1 to ev6 fuel injector connectors
gauges
Auto meter electric boost gauge
Auto meter wide band AFR
Auto meter electric fuel pressure gauge
transmission
Fully built 4l65E BY JR Racing transmissions
trans deep pan "3qts"
PI multi disc stall 3200
differential
Eaton posi
after market 3.73
Moser diff. girtle cover
custom drive shaft
suspension
DJM 4-7 drop kit
DJM rear shocks
Caltracs
wheels
Bogart wheels D-10 Bolted
front 15x4 hoosier runners
rear 16x10 hoosier 28x10 slick
custom system
custom box with 2 10 inch woofers
2 DB drive amps
custom navi. radio
EQ
and some more stuff. i dont know much about systems
when i run the truck nothing is removed only the original 20 inch wheels to install bogarts.i have'nt weigh the truck so what ever they weigh plus the system and the rest of the stuff added. that should be everything but if i think of something else that needs to be added i will up date my list.
tuning
motor
ASP crank pulley
custom MSD wires
NGK spark plugs
meth kit
TNT F-1 kit 75 shot
160 stat
Fuel system
SVO 42# injectors
gauges
transmission
differential
Eaton posi
after market 3.73
custom drive shaft
suspension
DJM 4-7 drop kit
DJM rear shocks
Caltracs
wheels
custom system
2 DB drive amps
custom navi. radio
EQ
#66
thanks. me and some other friends are planing on going to Houston soon so I'll let you know when we head out that way. you have a nice truck.
#70
tuning
motor
ASP crank pulley
custom MSD wires
NGK spark plugs
meth kit
TNT F-1 kit 75 shot
160 statpower stat
Fuel system
SVO 42# injectors
gauges
transmission
Fully built 4l65E
differential
Eaton posi
after market 3.73
custom drive shaft
suspension
DJM 4-7 drop kit
DJM rear shocks
Caltracs
wheels
custom system
2 DB drive amps
custom navi. radio
EQ
tuning
motor
ASP crank pulley
custom MSD wires
NGK spark plugs
meth kit
TNT F-1 kit 75 shot
160 statpower stat
Fuel system
SVO 42# injectors
gauges
transmission
Fully built 4l65E
differential
Eaton posi
after market 3.73
custom drive shaft
suspension
DJM 4-7 drop kit
DJM rear shocks
Caltracs
wheels
custom system
2 DB drive amps
custom navi. radio
EQ
