TIME SLIP DATABASE
Casper sets the bar once again on a 5.3L
Old Aug 21, 2008 | 04:23 PM
  #61
yeah thats true actually added weight jaja
Old Aug 21, 2008 | 05:00 PM
  #62
LaPompisRGV's Avatar
che edgar anda recio la casper...keep up the hard work and 10's are kreeping up!
Old Aug 21, 2008 | 05:27 PM
  #63
skeet's Avatar
casper casper casper, come on bro spill the beans!!!!!!!!!
pull the damn turbo out the tranny !!!!!!!!!!!!!!!!!
good luck on the 10s bro!!! i am sure you'll get there !!!
Old Aug 21, 2008 | 07:19 PM
  #64
edgarglz84's Avatar
Banned
esta bien tocayo.nice times.my name is edgar tambien and this is my truck so far.let me know when you come to houston aqui vivo.
<br>
Old Aug 21, 2008 | 07:28 PM
  #65
ls1CANTU's Avatar
9 Second Club
Here is the list of what's been done to my truck and everything was done at my shop. Im running 16 pounds of boost now and a 75 shot. I eather use meth or nitrous but not both at the same time. I have'nt been able to make it hook with the nitrous off the line so i spray after the 60 foot.
2008 chevy silverado 5.3L
tuning
All tuning done by me
motor
5.3L with 243 heads from factory "untouched"
custom XMS cam 224-222 581-581 lsa ?"i'll pm it to you if needed"
comp cams 7.400 push rods
comp cams 26918 springs
ASP crank pulley
custom MSD wires
NGK spark plugs
XMS custom BY NORIBILT front mount turbo kit. modified 76GTS turbo
twin front mount air to air intercoolers
3 inch down pipe with race magnaflow muffler and stock tail pipe no cut off
meth kit
TNT F-1 kit 75 shot
Throttle body spacer
160 stat
Fuel system
Dual walbro intank fuel system
Aeromotive boost ref. fuel regulator
stock fuel rails but modified to convert to retune fuel system
steel braided #6 line from tank to rails and returne to tank with #6 an
SVO 42# injectors
Fast ev1 to ev6 fuel injector connectors
gauges
Auto meter electric boost gauge
Auto meter wide band AFR
Auto meter electric fuel pressure gauge
transmission
Fully built 4l65E BY JR Racing transmissions
trans deep pan "3qts"
PI multi disc stall 3200
differential
Eaton posi
after market 3.73
Moser diff. girtle cover
custom drive shaft
suspension
DJM 4-7 drop kit
DJM rear shocks
Caltracs
wheels
Bogart wheels D-10 Bolted
front 15x4 hoosier runners
rear 16x10 hoosier 28x10 slick
custom system
custom box with 2 10 inch woofers
2 DB drive amps
custom navi. radio
EQ
and some more stuff. i dont know much about systems
when i run the truck nothing is removed only the original 20 inch wheels to install bogarts.i have'nt weigh the truck so what ever they weigh plus the system and the rest of the stuff added. that should be everything but if i think of something else that needs to be added i will up date my list.
Old Aug 21, 2008 | 07:36 PM
  #66
ls1CANTU's Avatar
9 Second Club
<br>
thanks. me and some other friends are planing on going to Houston soon so I'll let you know when we head out that way. you have a nice truck.
Old Aug 21, 2008 | 07:50 PM
  #67
v8
17,16,15,14,13,12,11 Drvr
come on edgar, I can record it for ya.
Old Aug 21, 2008 | 07:51 PM
  #68
chocheman1's Avatar
Registered User
congrats man, freakin great times, puro rgv
Old Aug 21, 2008 | 08:15 PM
  #69
o7z71's Avatar
thats all u got?
Old Aug 21, 2008 | 08:16 PM
  #70
o7z71's Avatar
tuning
motor
ASP crank pulley
custom MSD wires
NGK spark plugs
meth kit
TNT F-1 kit 75 shot
160 statpower stat
Fuel system
SVO 42# injectors
gauges
transmission
Fully built 4l65E
differential
Eaton posi
after market 3.73
custom drive shaft
suspension
DJM 4-7 drop kit
DJM rear shocks
Caltracs
wheels
custom system
2 DB drive amps
custom navi. radio
EQ
anything else?
