TIME SLIP DATABASE
cant figure this truck out . HELP
Old Jul 12, 2008 | 03:40 AM
RickLowpez's Avatar
Default cant figure this truck out . HELP
well 85 deg.weather,08 rcsb gmc 91oct tune. full bolt on 220 high lift cam , 3500( break stall 3200) edge converter,373s, 28 m/t and only a 1.94 60ft. but went 13.35 at 103.6 mph. all night 103 mph so i was happy on that but not the 60ft. i tried different rpms also but nothing worked . so do i need 410 gears? bigger stall? what could it be? need suggestions asap
Old Jul 12, 2008 | 05:53 AM
ap2002's Avatar
weather is too dam hot right now for you to expect good 60's, i bet your IAT's are way up there when you launch, which will pull timing netting shitty 60's,
on the good note, the mph sounds very promising, and i would definately do the 4.10 gear swap...
Old Jul 12, 2008 | 12:34 PM
RickLowpez's Avatar
ap whar rpm r u doing at,70- 80 mph with stocks?
Old Jul 12, 2008 | 01:01 PM
ap2002's Avatar
stock 17" tires, im at 2150rpm @ 70mph
Old Jul 12, 2008 | 04:17 PM
RickLowpez's Avatar
so at 80 ur at 2400 or so?
Old Jul 12, 2008 | 04:28 PM
circusboy's Avatar
my best 60 ft. was 1.88 with 26" MT's. My best 60 ft. on stock tires was a 1.9, lol. I wish mine would launch better too, I think with colder weather we will both be real happy
Old Jul 12, 2008 | 04:41 PM
RickLowpez's Avatar
may be 411s and a 3800 stall will fix the problem
Old Jul 12, 2008 | 05:32 PM
silver-mod-o's Avatar
Hunt&Fisherator
Your converter isn't the problem... Weather and gear are.
Old Jul 12, 2008 | 11:05 PM
RickLowpez's Avatar
dude it didnt seem that hot all runs were made in 80-90 deg weather.104 was the high 4 the day.it didnt seem hot
Old Jul 13, 2008 | 01:18 AM
BlackPearlZ71's Avatar
try smaller slicks Rick.. some 26s or 27s, you'll get a better launch out of them... try that, and check your pinion angle.. maybe it could be off and that also affects your 60fts.
