cammed lm7 needs track help
let me give you guys a basic rundown on the truck...
it's a 97 Xcab with a 5.3 swap, all i have is (2 pcm, one dyno for track and 1 from Wheatley for 87 octane daily driving)
TR220
Longtube headers
3200 278mm circle D stall
4" home depot intake
open axle on 3.42 gears with a 29" tire
3" cutout
it's obvious i have a traction problem
let me give you a timeslip from 3 months ago (haven't ran since then)
R/T .516
60 2.499
330 6.366
1/8 9.489
mph 79.56
1000 12.146
ET 14.415
MPH 98.36
I wanna get at least 13.5's out of this thing at the track, on the street it runs GREAT with both tunes, i've walked alot of things from rolls (g35,350z, FBO 6.0 ccsb/rcsb) but with the Annual track shootout in Baytown TX soon i wanna run some better track times
So far i have new parts that i collected since 2 weeks ago...
799 heads shaved .030 thousandths
NNBS intake with 4bolt 92mm TB
stock .051 head gaskets
Spool
The last thing i wanna address that i have not gotten yet is the slicks i want to run, I've read and seen people run anywhere from 26" to 28" slicks
so if you track guru's would help me out i'd appreciate it
TR220
Longtube headers
3" cutout
R/T .516
60 2.499
330 6.366
1/8 9.489
mph 79.56
1000 12.146
ET 14.415
MPH 98.36
Spool
TR220
Longtube headers
3" cutout
R/T .516
60 2.499
330 6.366
1/8 9.489
mph 79.56
1000 12.146
ET 14.415
MPH 98.36
Spool
TR220
Longtube headers
3" cutout
R/T .516
60 2.499
330 6.366
1/8 9.489
mph 79.56
1000 12.146
ET 14.415
MPH 98.36
Spool
The 3.42's are actually pretty good on the top end or from a roll as while some other people you are racing might have a shorter gear 4.10's or more (there vehicle might be more setup for the dragstrip) and while they are changing gears your long 3.42 gears are still in the powerband and has less shifting to do..
If you can't decide then pick a happy medium which would be 3.73 gears and please get a truetrac or something and you would be happy.
Start with the info / recommendations I gave you and go from there.
Gained 60 hp and made power past 5k with the nnbs intake, so i gained a bit.
i 1/4'd the truck today on the new setup .. new times are...
13.04 @ 101.97 2.003 60ft. i ran some 27" hoosier slicks on 15 psi, stalled up to 1400 and flashed it at the last yellow light
