TIME SLIP DATABASE
Better Times and MPH....
Old Dec 27, 2007 | 07:49 AM
Cuerva's Avatar
11 Second Truck Club
Default Better Times and MPH....
Decided to make a few passes last night with the same setup and all were a tad better than last time. Ran 12.23 @110mph w/1.65 60' hotlapping and full weight. Truck ran very cosistent 12.2's all night. My 60's ranged from 1.65 to 1.71; Managed to hook a little better but still spinning quite a bit. There may still be another tenth in her with better traction and stock intake. Can't wait to install the Caltracs and run the 10" wheels, I sure hope it helps.
Old Dec 27, 2007 | 08:16 AM
ap2002's Avatar
congrats on the new times cuerva!! those are some nice 60's, from what I hear them caltracs help quite a bit and that 10" wheel also, that mph is good for a 12.0!!!
Old Dec 27, 2007 | 08:43 AM
Cuerva's Avatar
My 1/8th times were 1.72's so I think there's a little more room by moving my shift points up a little more.
Old Dec 27, 2007 | 08:50 AM
ZR1 DREAMING's Avatar
Very good for hot lapping and running full weight
What exactly is your set-up? Those are outstanding times for a NA 6.0
Old Dec 27, 2007 | 08:51 AM
Originally Posted by la Cuerva
Thanks guys,
Mods are stock 317's massaged/milled .030"stock valves, 23x/24x 112 Custom Grind Comp Cam, 4k 3 disk PI Converter, 36lbs Fast Injectors. The rest stayed the same
Is this it???
Old Dec 27, 2007 | 09:00 AM
Cuerva's Avatar
Originally Posted by ZR1 DREAMING
Is this it???
Yes, plus the normal boltons
Dual springs, Titanium Retainers, 7.4" hardened pushrods, K&N FIPK, E-Fans, 160 t-stat, MSD wires, ASP Crank Pulley, Pacesetter LT's, Full Single 3" Exhaust W/Hooker and 3.5" E-Cutout, Fully Built 60E, 4.10's with Eaton Posi.
Old Dec 27, 2007 | 10:27 AM
TXsilverado's Avatar
NICE. if i ever make it to the valley we should line em up. the times are identical. i wish i could 60 as good as you though
Old Dec 27, 2007 | 11:26 AM
rgvsierra's Avatar
nice time Jorge.
Old Dec 27, 2007 | 05:16 PM
amadeospike's Avatar
Great times Cuerva, looks like you got the hang of your torque converter. Awesome MPH. Keep it up.
Old Dec 27, 2007 | 05:22 PM
Cuerva's Avatar
Thanks, not doing so bad yourself. Looks like you're the new fastest 5.3 n/a record holder.
