TIME SLIP DATABASE
baseline times
Old Aug 10, 2006 | 12:24 AM
Quik's Avatar
5 year bitches!
Default baseline times
well finally went ot track tonight. times arent bad considering the basemap and im still pig rich
i got a best of 12.8 @ 104 with a best 60" of 1.79
this is with stock suspension and just ET streets
i at first woudl dead hook then just blow the tires off thru first and then into second while going sideways on the 1-2 shift each time
track prep sucked!! this was done ALL motor and full weight minus the tailgate. i was on stock 16"/15" steel wheels along with a heavy speaker/amp box along with bunch of console crap and etc.
i think i should go to a 26" tire sicne i was only at 5400rpms going thru traps it seemed.
so with more tunning and how to figure out my hooking situation ill be at my NA goal soon.
also was a hot day
Old Aug 10, 2006 | 12:27 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Good times and a great 60'!
Old Aug 10, 2006 | 12:50 AM
Quik's Avatar
5 year bitches!
the numbers arent bad but im not totally happy. i wanted 2mph which probably will come from more tweaking of my A/F and my ET will drop once i hook
Old Aug 10, 2006 | 10:29 AM
silver-mod-o's Avatar
Hunt&Fisherator
hell yeah man, thats very solid for base times N/A... get it hooked and tuned a little better and you'll be flying!!!
Old Aug 10, 2006 | 02:59 PM
bluecajun5.3's Avatar
11 Second Truck Club
great times.
your mph won't pick up until the cooler weather.
and since you were spinning the mph is going to be higher than if you were hooking.
Old Aug 10, 2006 | 06:17 PM
TURBO8's Avatar
I think I would be happy with a 1.79 60ft. Try 2.2-2.6 . I need help with hooking. Good job, that truck moves.
Old Aug 10, 2006 | 09:54 PM
Quik's Avatar
5 year bitches!
im not happy im unloading the rear and blowing hte tires off. shows me i got alot more tuning of setup to do to get good 60s. theres alot better 60s in it cause of the power if i can get the suspension to transfer better
Old Aug 11, 2006 | 12:35 AM
02sierraz71_5.3's Avatar
That 60' should be putting you closer to 12.4 sounds like there is alot left if its spinning that much after the 60ft.
Old Aug 11, 2006 | 09:27 AM
rgvsierra's Avatar
good start, colder weather is right around the corner, cant wait for that.
Old Aug 11, 2006 | 10:36 AM
Quik's Avatar
5 year bitches!
yea cooler weather would be nice. suppose to be cool tonight but the local track open tonight is doing an event for the buicks. so i guess i got to wait but gives me time for tuning
