TIME SLIP DATABASE
another trip to the track with no 9
Old Nov 6, 2006 | 08:58 PM
Keith's Avatar
Originally Posted by TurboGibbs
Damn. Tough luck.
OK, you have convinced me. I am having my block o-ringed and running solid copper head gaskets before I stick it together.
Better run some Hylomar on those copper gaskets.
That sixty foot looks good without warming up the tires.
Old Nov 6, 2006 | 09:21 PM
KY_BOB's Avatar
Hang in there. We're pulling for you and you'll git 'er done soon enough.
Old Nov 6, 2006 | 09:31 PM
slowec's Avatar
Don't make me get out my pom poms! I almost 300lbs. It wouldn't be pretty. Buck up little camper. We'll beat that slope. Blacksheep who? You are Parish damnit. Now get that head gasket done ,find the right plugs and get them single digits.
or give up and sell me those wheels . I F'ed up not getting in on that purchase.
Disclaimer : If none of this makes sense, disregard...I have been drinking.
Old Nov 6, 2006 | 09:46 PM
dewmanshu's Avatar
Moderately Differentiated
hahahaha! I am with ya!
keep it up jim! get the right plugs in, good head gasket, and run her again!
Old Nov 6, 2006 | 10:18 PM
StrokerAce03's Avatar
Stick with it man; you already accomplished some pretty unbelieveable feats with a heavy *** 4wd, there's a 9 second slip in there somewhere I'm sure. How much boost are you running now and how big of a shot are you spraying?
Old Nov 6, 2006 | 10:56 PM
parish8's Avatar
single digit dreamer
i just ordered another set of the ics titan copper head gaskets($$$ ). they did last me a long time. i saw a few deg of knock on a lot of runs before they let me down.
this will give me a chance to clean up the chambers too.
i just want to sometimes. i look at the runs i have had the past 2 trips to the track and i could have had a nine had i done things differently. 2 weeks ago i was full weight and ran a 10.11, with 190lbs less weight it probably would have been a nine. last sunday i ran a 10.11 with a 1.61 60'. if i had warmed up the tires there is a good chance for a low 1.5 60' and likely a nine.
depending on the weather i am using between a 125shot and a 175shot to get me moving. 2weeks ago it was cold and a 125shot hit hard. 2 days ago it wasn't as cold and a 150shot didn't hit hard enough. truck was running hard 2days ago for the boost level i was at. around 17psi is all and not a great 60' so i am making progress. maybe next time. i am going to try and hit the track again on sunday.
Old Nov 6, 2006 | 11:05 PM
KY_BOB's Avatar
Like my old shop teacher told me about 20 years ago, IF a frog had wings he wouldn't bump his *** all the time".
You'll do it.
Old Nov 8, 2006 | 01:52 AM
thunderwagen's Avatar
You'll do it.
You will nail it soon enough and when you do all the broken **** and late nights will be worth it. Hell if it was easy we would all be runnin 9's instead of living through you!
Old Nov 8, 2006 | 07:59 AM
TurboGibbs's Avatar
Jim, is your block o-ringed? If not a machine shop should be able to do it with the engine in the truck. At least I don't see any reason why not. The groove cutter for the wire ring is a hand-held tool. Just a thought.
Old Nov 8, 2006 | 08:16 AM
Scream's Avatar
MOOBIES Moderator
Blacksheep was the first 2WD truck to get into the 9's. You can still be the first 4WD truck and first turbo truck to get into the 9's. Keep at it man, stay focused and you'll get it.
Did you try the cardboard over the grille? I ordered one of the nice stainless pieces from Putco....sure as hell hope it works!
