TIME SLIP DATABASE
9.70@135
Old Nov 22, 2014 | 11:18 AM
TimDave217's Avatar
what wheel is that you are running on your truck. i really like those!
Old Nov 22, 2014 | 11:21 AM
dragpac's Avatar
Weld allumistar
Old Nov 25, 2014 | 06:40 AM
dubwise's Avatar
What is the suspension/shock setup?
That thing is getting it done- Nice work!
Old Nov 25, 2014 | 01:06 PM
dragpac's Avatar
My original setup was stock leafs with 2 removed and competition engineering shocks with Lakewood traction bars set at 1/4" off the spring and that got me a 1.47 60' and the front wheels up off the ground.
now I have ladder bars and QA1 coil overs set on 6 and get 1.42-1.45 60'
Hope this helps you out!
Old Nov 25, 2014 | 01:08 PM
dragpac's Avatar
How do you run with your setup,it sounds impressive
Old Nov 26, 2014 | 12:18 AM
dragpac's Avatar
What do you mean ?
Old Nov 26, 2014 | 08:55 AM
BigBlock90's Avatar
id love to see some 60's like that with my truck some day aswell, Joel...lol i think my turbo LS gonna need alot more BOOST...haha
Old Nov 26, 2014 | 09:58 AM
dubwise's Avatar
Thanks for the info. Do you remember if the rear shocks were in the stock location on the 1st setup?
I'm still trying to work the bugs out of mine. I have zero traction with 325/50-r15 MT ET Streets w/a 60' of 2.25something. I don't have any traction aids yet. Once everything is dialed in I'll post up some times.
Crank up the boost, with some slicks in back and I'd bet you'd see high 10s or low 11s.
Old Nov 26, 2014 | 01:07 PM
dragpac's Avatar
I did move the forward shock to the rear,sorry I forgot about that.unless you carry weight in the back you only need 2 leaf springs and then it will be soft enough to plant the tire like a super stock car from the sixties
Old Nov 26, 2014 | 01:11 PM
dragpac's Avatar
Guys you need to remember,with leF springs you want separation between the tire and body to help plant the tire and with a coil spring you want it to sqaut to plant the tire
