TIME SLIP DATABASE
9,10,11 second trucks please come in
Old Jan 17, 2009 | 09:00 PM
  #21
quicksilverado's Avatar
Slicks will do that. Hold the wheel straight and ride it out. Its sort of like riding in a boat. The back end will move around a good bit.
Old Jan 17, 2009 | 09:55 PM
  #22
pittman's Avatar
I didn't know that...scared the sh*t outta me !! Felt out of control the whole way !!
Old Jan 18, 2009 | 11:33 AM
  #23
AustinDesigns's Avatar
Quicksilverado is right. First time I had slicks on, I almost pissed myself as well. Mine started doing it about 90mph. It is also due to low tire pressure as well. Remember, slicks will hook with more pressure compared to drag radials, because they are stickier. Might try airing them up a little next time to see if it helps with the top end wobble, I know it helped mine.
Old Jan 18, 2009 | 12:37 PM
  #24
pittman's Avatar
What psi ?
Old Jan 18, 2009 | 12:56 PM
  #25
litreddevil's Avatar
Banned
Originally Posted by pittman
What psi ?
i would start off with 25 psi and go down from there.2 psi at a time when it hooks then you will be good.i have seen trucks have 28 psi and hood and was running in the low 10's
Old Jan 18, 2009 | 02:57 PM
  #26
pittman's Avatar
I'll try again. I never went over 19.5
Thx
Old Jan 18, 2009 | 04:38 PM
  #27
I start at 18 psi. If the track holds I leave it there. Normally have to drop it to 15-16 psi. Make sure both tires have the same pressure or it can cause the truck to pull one way or the other. Just hold the wheel straight and the back will follow. Its a good idea to check them during the day also. If one tire is in the sun and the other one is not. The one in the sun will have more air pressure after a while. The tire pressure will also go up if you are hot lapping from the burnouts.
Old Jan 18, 2009 | 05:32 PM
  #28
pittman's Avatar
Yeah, I check my pressure after each run when hot lapping and usually allow 2-3 lbs when cold for expansion. I couldn't get near 15 psi..was swerving near 20.
My 4 link rear may not go well with wide slicks ?? I don't know what to think ?? Would like to try some skinnier slicks but would need to sell these.
Pitt
Old Jan 18, 2009 | 09:59 PM
  #29
Make a few passes and gradually increase the speed up top. It just takes some getting used to.
wrb002
Aug 31, 2015 12:00 PM
Suburban2500
Jul 19, 2015 04:50 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
black6spdz
Jul 16, 2015 01:32 AM
Nimoryan
Jul 5, 2015 03:50 PM
