TIME SLIP DATABASE
7.40 @ 90!!!
Old 06-22-2010, 03:03 PM
  #21
00buckshot's Avatar
Originally Posted by fastrt
good times man! where was your AFR when you were running? what was the DA also? Nitrous Outlet plates are hard hitting plates. I couldnt stick my old slicks with a 100 shot running the time in my sig. now with new cam and heads and intake with the same 100 shot I would like to see 7.40's too, but I have some hoosier 28x10x16's slicks to try when the weather is cooler. congrats!
stew, best motor pass was an 8.95, sorry forgot to put it in there! Don't take me for a dumbass but I don't know what the DA is or was, insight please? I feel so dumb every time i read DA and dont know wat it means.
Hey fastrt, I never had luck hookin on Hoosier's, unless i got em HOT AS ****!!! so I stick with my M/T's
Old 06-22-2010, 03:36 PM
  #22
BigKID's Avatar
DA = Density Altitude. It is an air density equivalency calculation factoring in temp, humidity, barometric pressure and altitude.
Congrats on the new times. Looks like you have your setup working well.
Old 06-22-2010, 04:28 PM
  #23
skeet's Avatar
Originally Posted by 00buckshot
Yea, I was pretty impressed with the 60' myself considering I have lakewood universal traction bars and stock rear suspension, besides lowering shackles, runnin a 28-10.5-15 M/T drag, but I've reallt got to get it to plant and stay down thru the 60', it plants down and then unloads very quick after the hit
if you work the suspension it'll correct the unloading, you'll gain better times your MTs i run them also, but which compound do you run ans is the side wall stiff? i plan on switching to a softer sidewall and a softer compound!!
great times by all means !!!
Old 06-22-2010, 04:44 PM
  #24
TXsilverado's Avatar
my mt slicks work GREAT compared to my hoosiers.
check this out. it makes DA calculations simple.http://www.dragtimes.com/da-density-...calculator.php
Old 06-22-2010, 07:17 PM
  #25
pittman's Avatar
That suspension is like free HP..good run
Old 06-22-2010, 07:57 PM
  #26
KDavis04ss's Avatar
Good times man. It's cool seeing these heavy trucks running low 7s in the eighth. Should be putting my 228r cam in this weekend. Y'all need to make a trip to Douglas. I wouldn't mind trying my new setup when the weather cools back down. I'd be happy with a 7.4 when I'm done. Maybe a grudge match? Ha
Old 06-22-2010, 09:07 PM
  #27
Banned
litreddevil's Avatar
nice times !!!
Old 06-23-2010, 05:47 AM
  #28
slowec's Avatar
BTW, what was your mph in the Z when it went 7.66?
These times were from earlier when it was cooler.
1.67 60ft
7.66 1/8
89.8 MPH
I have put on a ls6 intake and deleted the front sway bar and a/c and added dry N2O so I expect better times now
Old 06-23-2010, 06:46 AM
  #29
00buckshot's Avatar
1.67 60ft
7.66 1/8
89.8 MPH
Lookin for some teens??
Old 06-23-2010, 06:50 AM
  #30
00buckshot's Avatar
Skeet, I know that its not the really soft compound with the S after the size, but I run a pretty lazy sidewall cause theyw ill wrinkle pretty damn good!
Quick Reply: 7.40 @ 90!!!
