2wd VS 4x4 for drag
So I have all the parts to put together my truck, and had the ida of switching things up before I start work on the truck and going to a 4wd truck. Iv seen one or 2 fast 4wd trucks out there so I know it can be done. Just haven't know anyone first hand who has built one
What do you guys think I should do
right now I have a bone stock 4.8 RCSB 05 gmc Sierra I could sell and get a 99 RCSB 5.3 z71 silverado, that's on craigslist
I have a 408 and Ysi supercharger about 1,000hp
I have a built 4l80 (my tranny guy will extange for a 4wd set up)
I have all the suspension for my 2wd truck
No doubt you need 4wd if you want to even think about being able to hook on the street. Modding a 2wd truck with a ton of power is retarded IMO. You have the traction issues a high HP car has, and the downside of a truck with the aerodynamics of a brick and you get to haul around an extra 1500+#s. I've beaten much faster cars in ky truck simply because I press my magic traction button and the race is over before I get to the other side of the intersection.
FYI 1000hp and DD/work truck don't mix, unless you've got a backup vehicle.
NOT having to swap to drag radials or slicks is a blessing only a 4x4 will know. If you were going for an all out drag truck then 2wd but otherwise NOTHING will launch as hard as a 4x4.
Ok so it's a huge push to go 4wd, is there anything I need to know b4 jumping into this, things I'll need or at least to look out for?
Things off the top of my head I don't know about 4wd truck?
How do you lower a 4wd truck
I know the 4l80 will be good and iv heard the 2500hd transpher case is goof for 2000 tq what about the front diff and axels
9 Second Truck Club
4wd is the only way to go for big power on the street. At the track a properly 2wd will be a good amount faster. Once you get past mid 1.4 60's the 4x4 will start to wheelie, and screw you. Also requires 4 slicks to hook at the track, which kill mph. All said 4x4 is better in my opinion for a street/strip truck unless you roll race from 80 on.
