TIME SLIP DATABASE
2002 2500HD RCLB 2WD "build"
Old May 23, 2013 | 01:19 PM
hog's Avatar
hog
Curb weights for 2004
3/4 ton
2wd
Red cab longbox C2500LD is 5059lbs and a rclb C2500HD 5153lbs
4wd
RCLB K2500HD is 5440lbs.
1 ton SRW
2wd
C3500RCLB 5612lbs
4wd
K3500 RCLB is 5841lbs
4400lbs is reg cab 1/2 ton truck weights.
peace
Hog
Old May 25, 2013 | 05:21 PM
custm2500's Avatar
Ph.D. in HUBRIS
I can assure you my 2001 2wd 2500LD never weighed over 5000#s. I am sure that 4400 or 4800 was it's factory weight.
Old May 25, 2013 | 06:40 PM
kelsey_canard's Avatar
4400 is light. My truck in the SIG weighed 4300 with me in it(180). That was with no spare, tailgate, spare tire winch assembly, tubular lowers, and quite a bit of weight removed from the exhaust I would think 4800 would be more correct. That's still pretty light. I want to say denmahs weighed right around 5000-5100. Don't quote me on that though.
Edit: Just checked, denmahs weighed 5060 with him in it.
Old May 26, 2013 | 12:35 AM
custm2500's Avatar
Ph.D. in HUBRIS
I wasn't in mine so maybe 4800 is my stock curb weight. That would make sense with and average man weighing 200 ish.
I think as a short bed it is 4200.
Old May 27, 2013 | 09:33 AM
silver-mod-o's Avatar
Hunt&Fisherator
There's no way you lost 600lbs by sectioning the frame that little bit and doing a shorter bed... There's not that much material there...
... Unless you're talking about the weight savings from removing front brakes or cutting holes in your frame rails for side pipes... Now that might get ya there...
Old May 27, 2013 | 04:08 PM
custm2500's Avatar
Ph.D. in HUBRIS
The shortening I think dropped me about 300-400 lbs if I am correct. I don't believe I removed much else when I went from long bet to short. Less frame, 4 links vs. leafs, and shorter bed.
Old May 27, 2013 | 11:50 PM
Hunt&Fisherator
anything besides guesses?? have you EVER had the thing across some certified scales? I'd be willing to bet your still several hundred pounds heavier than a half ton RCSB. heavier suspension parts, heavy rearend, heavier frame.... how bout something besides speculation...
4400-4800 is stock RCSB half ton territory, not a 3/4 ton long bed. I know these figures to be fact, not guesses
Old May 28, 2013 | 06:33 AM
custm2500's Avatar
Ph.D. in HUBRIS
Yes. It was on a scale 3 times. It was years ago. I will dig the slips if I can.
Stock as I bought it. 4800 I think
The usual stuff out. 4400 I think
Short bed, 4link. 4200 I think.
Let me see if I can confirm that.
Old May 28, 2013 | 06:42 AM
ak2007r6's Avatar
in for slips
Old May 28, 2013 | 04:36 PM
custm2500's Avatar
Ph.D. in HUBRIS
I just looked and found about 75 time slips but no weight tickets. I just saw the lightest one a few weeks ago. 4280 I am 99.9% certain was the weight with out me in it.
I am thinking it is out in the garage in my tool box possibly. It is pouring rain and I will look for it later or tomorrow.
