TIME SLIP DATABASE
16X10 or 16X8 for 28/10.5/16 Hoosiers
Old Sep 16, 2010 | 10:52 AM
bluecajun5.3's Avatar
11 Second Truck Club
Originally Posted by slowec
I found a wheel company that'll build me a (16 X 10 w/6.5 BS) cragar soft 8 style wheel for 150.00. And I can buy a matching 16 X 7 for the front . I'll add pics when I get it all done.
you still going to have problems with the banjo bolt. you will have to switch to an s10/blazer caliper with that much backspacing. this is a stock 16x7 rim.
Old Sep 16, 2010 | 11:17 AM
slowec's Avatar
Evilgmc ...yes, you know good or bad about them?
Lance... Thanks for the heads up.
Old Sep 16, 2010 | 11:52 AM
BigKID's Avatar
Wonder if the 8" would be much more stable than the 7 you run?
I would say it would. 1" may seem insignificant but it is 10% of the treadwidth. It is also within the recommended range. Since you are going to have some wheels made, check if they have a 9" hoop. This will keep the wheel/tire tucked in better and give you the stability you need. A 10" rim w/6.5" bs is going to put the tire just at the outside edge of your fender so they will be just shy of tucking. A 9" rim with 6"bs would be just about perfect IMO.
Old Sep 16, 2010 | 09:14 PM
sixltrbtr's Avatar
Hey bluecajun5.3, thanks for the pictures. It looks like there is about an inch between the edge of the wheel and the bolt. Have you measured it? Is that a Tahoe wheel?
Old Sep 17, 2010 | 12:45 PM
slowec's Avatar
Has anyone ran a 325/50/15 on these trucks???
Old Sep 17, 2010 | 09:02 PM
EVILGMC's Avatar
stockton wheel has been around for a long time...talked to them a while back about getting some custom rally wheels made....never did though.
Old Sep 18, 2010 | 07:57 AM
yeah it's around an inch. it's a stock silverado wheel.
Old Sep 18, 2010 | 08:11 AM
Atomic's Avatar
I have a gauge for that
Old Sep 18, 2010 | 08:19 AM
slowec's Avatar
Yep! I would think 9.5 wide with 6.5 bs would sound ideal to me then. I think Lance's photos show that 6.5 b/s works ok as well as bogart's use that bs . Good discussion guys!
Old Sep 18, 2010 | 08:20 AM
slowec's Avatar
has anyone ran a 325/50/15 on these trucks???
anybody???
