TIME SLIP DATABASE
16.4 with crappy traction
Old Aug 15, 2010 | 01:17 PM
iamkeniff's Avatar
if you're gonna take the time an labor to pull the converter you might as well put a 3000 vs a tb converter imo.
get a locker and a set of gears youll be happier
Old Aug 15, 2010 | 01:47 PM
rel3rd's Avatar
11 Second Club
Wink
Originally Posted by Suddog
The track here is a bit on the ghetto side. They have a tree but it doesnt work as most of the lights are out. A guy stages the vehicles and then drops the arms to start us.
So, this is Pinks All Out, Guam Edition????
j/k, if you guys are starting by "arm drops", smart money bets that your actual TRUE ET is far from accurate.
Old Aug 15, 2010 | 02:16 PM
Suddog's Avatar
LMAO
Yeah except our bald guy speaks Chamorro. jk For what it is worth...A racing track on a relatively small island with a total population of 170K, it is not a bad track, just a bit ghetto. It is cheap to run there. $5-6 a vehicle to get in and $2 each pass down the track. On any given Friday night, there might be a 15 minute wait between passes. The locals mainly run Nissan and Toyota pickups with 15 second times. There are a bunch of great people to race for fun against.
Old Aug 15, 2010 | 04:33 PM
outlawz2004's Avatar
Charlie must really have my 4.8 dialed in, my truck ran 16.3 stock with full street weight, nothing removed. With a K&N complete intake, descreened MAF, longtubes, offroad Y pipe with dual exhaust, and his dual tune it runs consistent 14.5s/14.6s with a best of 14.4 on the smaller street tires and weight reduction. It went 15.1 on 20s and at street weight. Still with stock trans/stall, stock cam, 3.42s and a peg leg.
Old Aug 15, 2010 | 09:57 PM
zippy's Avatar
I can only guess that you were pre-loading the converter too hard. A 4.8L with a stock converter should never have a traction problem. I'd recomend going with an inexpensive Auburn unit and adding the TB converter. You should pick up about a full second between the two mods.
Old Aug 15, 2010 | 10:25 PM
I have a stock converter and have traction problems. If I leave at idle, I spin for a few feet. If I stall it up any, I'm blowing the tires off. Now if the track is really prepped good, I can leave at idle without spinning.
Old Aug 15, 2010 | 11:25 PM
zippy's Avatar
The open diff doesn't help, but what tire are you running? It shouldn't take much track prep to keep a 4.8L from spinning. Either way, a good posi will make that truck so much more fun. Even a used Gov-Lock for a 100 buck or so would be well worth it.
Old Aug 16, 2010 | 02:02 AM
Suddog's Avatar
Maybe that was my problem. I was stalling it up at the line. I stalled my truck before I modded it up, but traction wasnt that big of an issue. My traction problem came double fold after all the mods.
I will try not stalling next Friday (if it doesn't rain)...hopefully Wheatley has a new and improved tune for me as well.
Old Aug 16, 2010 | 07:25 PM
06Sierra2's Avatar
Are you on street tires? If so what size and psi do you run them at the track? Do you go around the pit? Just curious cause last night i ran 16.8 at 82 spinning bad also. with your mph though it seems like you could hit a high 15
Old Aug 16, 2010 | 08:21 PM
gs7793's Avatar
wow....this just made me completely decide not to mod up my 4.8 and start saving for a 6.0 lol
