TIME SLIP DATABASE
11 sec radix ec attempt?
Old Oct 27, 2006 | 02:58 PM
Last Call's Avatar
TOTM: January 2007
Default 11 sec radix ec attempt?
I am wondering if I could squeeze an 11 out of my truck.
My best run so far is as follows;
60'-1.977
330'-5.369
660'-8.144
mph-88.70
1000'-10.534
1/4-12.56
mph-110.78
Another track locally is usually about .3 faster. I think its going to come down to the 60'. Im going to need a 1.80. The mph is there i think.
Old Oct 27, 2006 | 03:01 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
My best 60" is 1.82 and I'm really consistant. Your a bit lighter and are 2wd so you have an edge there.
Hook a little better get those 60' down tio 1.7x
Dump the amps, spare seats, everything that isn't glued in including door panels etc and you will hit it!
Old Oct 27, 2006 | 03:04 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
what tires are you using at the track?
Old Oct 27, 2006 | 03:30 PM
Last Call's Avatar
TOTM: January 2007
28x11.5x16 et streets.
Old Oct 27, 2006 | 06:40 PM
litreddevil's Avatar
Banned
what are you crossing the line at (rpm) if it is not to high go with some 4.10 with 28" tall it should work
Old Oct 27, 2006 | 07:03 PM
TURBO8's Avatar
You can do iiiiiiiittttt!
Old Oct 28, 2006 | 12:08 AM
ap2002's Avatar
dont know you are running some damn good times...
have you done any weight reduction?? get you some 16x10 wheels on them e/t's...
Old Oct 28, 2006 | 12:56 PM
Last Call's Avatar
TOTM: January 2007
I did some weight reduction. Backseat, subs, tailgate. What else is there. Maybe the hitch. Take the 22's off of the front?? My amps and processors is probably at least 100#'s, but I dont want to remove all that stuff.
How do you get down so low in weight?? My truck is a fat pig compared to yours.
Blue03sss
Mar 7, 2019 05:06 PM
bagged7104SS
Sep 24, 2015 08:42 PM
whitelazer
Sep 22, 2015 09:38 PM
Pimpinpete
Sep 8, 2015 07:39 PM
mayko
Sep 7, 2015 12:24 PM
