TIME SLIP DATABASE
10.8's ALL night long! 72mm tapped out?!
Old 10-09-2011, 10:52 AM
La Blue 05's Avatar
Nice times ....
Old 10-09-2011, 11:14 AM
05_GMC's Avatar
Man your trucks sick, i had black with red stripes before i murdered mine. Have my 6.0 turbo an e85 conversion in hopefully before winter. Then start saving for a 80e
Old 10-09-2011, 11:16 AM
11 Second Truck Club
fastrt's Avatar
1.57 aint no slouch! There are lots of things you can do to low it if need be. I wish I could say I only ran a 10.8 all night!
Old 10-09-2011, 11:43 AM
foose04's Avatar
Originally Posted by slowec
NICE. that will inspire many.
Are you coming to the STS race in Ga on November the 19th???
Thanks man, I hope I can make it this year but it depends on my work mainly.
Sharpeshooter: I run 100% E85, nothing else.
Silver: I do have the front sway removed.
Tarinitup: I currently have lakewood 90/10's on the nose and rancho's set on 9 firmness on rear.
And to all the other gear heads thanks for the support and help with getting the truck this far. I always have fun running it and enjoy be a little different out at the track then most setups. The little GM holds it's on and i'm blessed/thankful god keeps me off the walls and gets me home!
Old 10-09-2011, 11:53 AM
9 Second Truck Club
tarinitup's Avatar
Firmest was going to be my suggestion. It goes against stuff you read online that you want rear to squat but hooks better
Old 10-09-2011, 12:54 PM
Hunt&Fisherator
silver-mod-o's Avatar
Right. You dot necessarily want the rear to squat hard. But picking the front up will transfer the weight to the rear of the vehicle and plant the tire. It looks like the cal-trace are working but I still think you have a good bit left in the 60ft
Old 10-09-2011, 01:20 PM
SincalT/A's Avatar
I agree with the guys saying keep the rear firm.My best traction has been when there is jus enough squat for roll out if you get what that means.Another way to put it would be squat happens soon as you let off the brake.Im talkin like a 1"-2" drop in the rear no more.
Whats kind of back pressure is in the log under at 18psi?
I'd imagine e85 would compound a backpressure issue?
Old 10-09-2011, 01:37 PM
Swerve7rpm2000's Avatar
Foose how much boost u leaving on? If mine was that consistant in the 60's id be happy lol.... I get a 1.64 when it does hook but im also looking for some weight transfer off the line, i do that 60' with the standard 4" Beltech Spindle/shock drop... I dont see much transfer in yours even with the 90/10 shocks and that is the route im about to go
Old 10-09-2011, 02:58 PM
foose04's Avatar
Not sure on current back pressure, I wonder the same thing though. Why do you think E85 would add to back pressure? Extra fuel volume?
Here is a slow-motion from another night. This is leaving at 3500-9psi boost.
Launch - YouTube
Old 10-09-2011, 03:11 PM
Ph.D. in HUBRIS
custm2500's Avatar
I know you like the " it has 20s on it" but to me it isn't very true anyhow having smaller out back. Get some skinnies up front and you will be able to keep all the weight on the rear tire longer. As soon as the front tire is about to come off you can see the truck stop transfering weight.
Truck is kickass no matter how you cut it. Damn good looking, fast as hell, and cool on a 4.8.
You going to swap to a 6.0 if your hand in forced?
Quick Reply: 10.8's ALL night long! 72mm tapped out?!
