97 5.2 motor stumbles help.
Old Sep 25, 2005 | 11:12 PM
Default 97 5.2 motor stumbles help.
i bought a grand cherokee 97 5.2 and the motor has a problem ,,you rev it and when the rpms are going down it dies and / or idles roughly also the motor overheats <<< it leaks all the water but dont konw if it is the radiator or a simple hose. anyone have an idea? thanks.
Old Sep 26, 2005 | 06:14 AM
BigPurp's Avatar
How many miles on it?
More than likely has a blown plenum gasket (very common) that can cause a funky idle, and make it knock like a sum bitch.
Check the IAC solenoid in the t/b as well.
How much coolant is it losing? Is it dumping on the driveway or just mysteriously disappearing?
If it's a high mileage (150k+) prob needs a timing chain, good tune up, and a few other little things.
Old Sep 27, 2005 | 11:12 PM
thanks i took the radiator off and was very bad i am having it welded tomorrow then i will try to fix the motosr prob. it has 127,000 miles.
Old Oct 8, 2005 | 06:10 PM
1Red Dawg's Avatar
Its more than likely the IAC on the throttle body. I had the same problem a few year ago on my 97' 5.9L and I replaced that and problem was gone!! Hope this helps!!!
Old Oct 8, 2005 | 09:49 PM
MrDestinE's Avatar
Be sure to check for exhaust gas in the radiator... if the plenum gasket blows, most likely the water is in the oil but if the head gaskets are leaking, then if it is not yet going into the oil it is going out the tailpipe..... will be in the oil soon
Old Oct 9, 2005 | 12:12 PM
thanks turned out to be the spark plugs and i cleaned the thtotle body with carb cleaner. the transmision would not let the truck run freely at start but it was a sensor ,,its running great now. i even beat a durango hemi sweet.
Old Oct 25, 2005 | 03:34 PM
1Red Dawg's Avatar
good to hear it wasnt anything major!!!
TXsilverado
Nov 26, 2015 10:54 AM
Mossyoakglock
Aug 28, 2015 12:49 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
Nimoryan
Jul 5, 2015 03:50 PM
