Inside a HEMI engine
#21
Originally Posted by ktmrider
Rollers will reduce friction and wear plus allow for faster rev's. May not benefit the F/I folks but personally I'll take any help we can get these days!
The cam specs you posted will be better for the turbo ( split duration with higher intake value, larger LSA ). The +5 advance will help off the line but require a bit more tuning work to avoid detonation ( BAD, trust me! ).
As always we are looking forward to the end results!
#22
Colt,
If I am not mistaken that cam has a -4* overlap which will definately help with the boost... if it had positive overlap some of the boost will be going out the tailpipe.. I have thought about asking if that particular cam would help over the stock one.... probably be RPM limited without the boost ... Got to be great for your application though.
Curious.... do you have any idea what your final static compression ratio will be??
TJ
TJ
Noah Burns
Sep 7, 2015 05:50 PM
signguy62
Jul 27, 2015 03:42 PM
atxlt
Jul 20, 2015 11:06 PM
