Dodge Engine & Exhaust Performance All EFI, Hemi, Magnum, 4.7, 5.9
Inside a HEMI engine
Old Apr 4, 2006 | 01:46 AM
ktmrider's Avatar
Originally Posted by hemidup
After doing some intensive studies with these heads. The LS1 Comp valve springs work great but, when using the Comp retainers, we found we had to machine down the rockers for clearance issues. By using the LS1 Comp valve spring and a Manley retainer, the clearance issue went away. We decided to just go with all Manley products. The Manley spring has 30lbs more pressure when open, which should also help when using larger (heavier) valves.
Hmmm, maybe I bought my CC stuff too early?!?
Old Apr 4, 2006 | 04:36 PM
hemidup's Avatar
If your sticking with the 5.7 cam you should be okay with the rocker issue. It's only going to the 6.1 or another high lif,t after market cam, is when you should be concerned.
Old Apr 4, 2006 | 07:50 PM
MrDestinE's Avatar
I have just got to wonder.....just how much pressure will the stock rocker take? I for one am just NOT impressed by the looks of the rocker, just does not look very strong to me.... I am also wondering how far off the ratios are from the blueprint.... have seen many stock rockers that were laughable on the ratio... I would love to see some rollers come out, I only know of one person working on them..
TJ
Old Apr 5, 2006 | 01:53 AM
ktmrider's Avatar
Thx Jerry, maybe I'll talk to Art ( bought from ) since I ordered the 6.1L cam and all the valvetrain stuff together....
Old Apr 5, 2006 | 01:34 PM
ColtSteele's Avatar
Who's working on the rollers TJ?
Old Apr 5, 2006 | 04:27 PM
MrDestinE's Avatar
I think I read somewhere that Stu was working on them but I am under the impression that he would be trying to find production facilities..
TJ
Old Apr 5, 2006 | 06:16 PM
hemidup's Avatar
SharaDon is also working on them. So far we see an issue with valve cover heights and coil packs. It's still a long way off with the high lift solid cams working with the stock PCM. Hot rodders can enjoy it though, just not us truck guys for the moment.
Old Apr 5, 2006 | 08:41 PM
MrDestinE's Avatar
yea don't remind me!
TJ
Old Apr 5, 2006 | 09:45 PM
ColtSteele's Avatar
Well the valve cover height may not be a problem. I'm working on something with a local machine shop that may help with that (wasnt trying to for that reason but if it makes it where they will work, sweet!). Now the coil packs... that's different. I havent even thought about them. Without my truck here it's difficult for me to get creative. I don't think about all of the obstacles if I can't see them.
I "think" (thats funny isnt it) my 220/230-547/557 114 cam is out and a 228/224-554/547 115+4 is going in. It should work better with boost. Anyone have any thoughts on that? If not, I may post it over in the Forced Induction section to see if anyone will help a Dodge guy LOL
Anyway- how would the rollers benefit us?
Old Apr 6, 2006 | 02:09 AM
ktmrider's Avatar
Rollers will reduce friction and wear plus allow for faster rev's. May not benefit the F/I folks but personally I'll take any help we can get these days!
The cam specs you posted will be better for the turbo ( split duration with higher intake value, larger LSA ). The +5 advance will help off the line but require a bit more tuning work to avoid detonation ( BAD, trust me! ).
As always we are looking forward to the end results!
