Dodge Engine & Exhaust Performance All EFI, Hemi, Magnum, 4.7, 5.9
Fuel Return & Stock Pump
Old Feb 20, 2007 | 06:17 PM
ScojoDak's Avatar
Default Fuel Return & Stock Pump
Do any of you forsee a problem having a fuel return system using a stock, in the tank fuel pump? I will be using the aeromotive regulator (see pic below) and return line adaptor (see pic below). Provided the fuel pressure is correctly set, will the stock pump overwork itself? The motor is a 1999 5.2 in a dakota club cab.
FYI, HP output will be no more than 325/350 when done with upcoming mods. I know the stock pump should be able to feed the motor ok. I want this set up because it looks cool under the hood, possible juice usage later, and I believe there will be some "cooling" of the fuel because of the return line. Yes, I'll be running aftermarket fuel rails that have AN fittings all around. So....
Your thoughts, opinions, suggestions, flames, bashings and insults are encouraged and welcomed. Thanks in advance.
http://www.jegs.com/images/photos/700/710/710-65385.jpg
http://www.aeromotiveinc.com/prod_im...10-1-small.jpg
5.3Okasai
Mar 9, 2022 01:07 PM
lxcoupe
Jul 21, 2015 02:12 AM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
black6spdz
Jul 16, 2015 01:32 AM
