Can i use both edge modules at the same time??
Old Aug 22, 2008 | 10:24 PM
Default Can i use both edge modules at the same time??
Hey guys i was wondering if on a 1998 dodge cummins 24v wit the edge power module already installed can i stack another edge EZ box programmer and run them both?
Old Aug 25, 2008 | 01:28 AM
What about a smary tuner on tp of the edge power
Old Sep 4, 2008 | 05:23 AM
overdrive's Avatar
Not sure about the older trucks. But probably not a good idea to stack the two. IF it is an Edge EZ module, it will stack with the Smarty. But I don't know if they made an EZ for a 98'.
Try Cummins Forum and ask that question. They will be able to give you an answer.
Randy
Old Sep 4, 2008 | 07:49 AM
NoChrome's Avatar
I did this with my truck, I put a smarty on the computer and had another box wired in under the hood. It went from "not bad for a diesel" to **** your pants fast. But your going to need tranny upgrades, pyro gauge, and a new fuel pump. I was able to roast 35" bfg mt's in 4wd, i went from 300 hp and 500 torque to almost 500 hp and a little over 800 torque, with some other fairly cheap mods
Old Sep 4, 2008 | 08:10 AM
JakeBrakeIH's Avatar
if you go through with it you better make sure your lift pump is in top notch condition or you'll be starving the ol VP-44 put a fuel pressure gauge on it and watch it...along with boost and pryo...or else you'll be melting stuff
ARC
57
Feb 21, 2022 10:54 AM
mzoomora
Jan 3, 2016 07:06 AM
chvy=power
Aug 17, 2015 12:21 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
