500 hp reliable
Old 12-20-2010, 11:00 AM
BANSHEEATER's Avatar
Default 500 hp reliable
I have an 02 cummins i was wondering what all i would have to do to make 500 hp and have the whole truck be reliable even when pulling my fifth wheel it is an auto trans
Old 06-21-2011, 10:51 AM
zrultima's Avatar
Comin from a guy who has a 2nd gen first and foremost you need an airdog, secondly vp44 monster pump 150 injectors, valves and studs, and a silver bullet turbo 500hp takes about 5 g if u do the work urself
Old 07-04-2011, 09:48 AM
Nospark's Avatar
First things first you should have your 47RE built before you worry about the motor. Triple disk converter, upgraded alto reds, performance Vavle body. A billet input shaft would not hurt since the transmission would already be out, but it not necessarily needed.
Old 09-03-2011, 08:54 PM
Duramaxin14's Avatar
Originally Posted by zrultima
secondly vp44 monster pump f
Why go with a monster pump when the stock pump will make this power number and live as long as it gets the right volume of fuel?
Old 09-11-2011, 09:41 PM
64mm turbo, 150hp sticks, air dog or fass, studs (i run A1 H11 studs), good tuner. The stock vp44 will push 500whp if its in good shape still. Do not go larger than a 64mm compressor unless you do a compound setup for towing. Something like a sps62 would work at 500whp, but would run high egt. Killer spool for towing though.
And of course a built trans.
nabozny21
10-17-2015 07:47 PM
Quick Reply: 500 hp reliable
