2003 cumming 5.9 problem. need help
Old Jul 1, 2009 | 10:41 AM
hammer71's Avatar
Default 2003 cumming 5.9 problem. need help
my 03 will not go above 2100 rpms. if i do, it's like a governor kicks in and takes it back to about 1000 rpms. what is my problem. the truck is a auto with 127k on it. nobody seems to know why it is doing this. truck is completely stock.
Old Jul 6, 2009 | 10:44 AM
Jeteys5.3's Avatar
this happened to my buddys dmax once.......his fuel filter was clogged with bits of junk due to getting some bad fuel the last time he filled up. Might wanna check the fuel filter and make sure its good to go.
Old Jul 6, 2009 | 10:49 PM
L7 Sierra's Avatar
I had a similar prob when I drove big rigs. Diesel absorbs tons of water compared to gas, and your probily hittting the filters restricted limits when you rev it up. Thus causing lack of rpm for a minute.
I changed my filters on the side of the road, and presto. I always had spares, and you should too.
Old Jul 7, 2009 | 09:08 AM
hammer71's Avatar
filter has been replaced and it still does it, im starting to think fuel pump, it runs fiine just won't push the rpm's up
Old Jul 7, 2009 | 10:36 PM
Jeteys5.3's Avatar
i'll ask some of my diesel buddies tomorrow for ya
Old Jul 8, 2009 | 09:33 PM
hammer71's Avatar
thanks, i'm not getting too much info on this
Old Jul 9, 2009 | 10:16 PM
Jeteys5.3's Avatar
ok, What codes do you get when doing the key [on off on off on] this should show codes in the odo display?
Old Jul 10, 2009 | 09:05 PM
hammer71's Avatar
no codes at all, this thing runs perfectly until about 2100 rpm
Old Jul 10, 2009 | 10:15 PM
Jeteys5.3's Avatar
ok i'll tell them, i'll let you know more tomorrow
Old Jul 10, 2009 | 11:20 PM
05GMCL33's Avatar
What's your fuel pressure at idle and high idle? What is the boost pressure doing?
