12 valve evac system
Old Mar 3, 2012 | 08:17 PM
TheGreat4.8's Avatar
Default 12 valve evac system
What kind of crankcase evac system does a 1st gen Cummins use?
Old Mar 4, 2012 | 12:49 AM
smokeshow's Avatar
Mod with training wheels
Friend with a P-pumped 1st gen says:
Originally Posted by BigRed Cummins
Driver's side rear of the tappet cover on the engine there is a hose that runs down to the ground. Are you getting lots of oil leaks from excessive blow-by? Unfortunately those motors are known for having blow-by issues. There is a valve cover crankcase vent available from Case tractors that helps a great deal, and some guys drill their stock valve covers and install universal breather filters.
Old Mar 4, 2012 | 01:01 AM
Hah you are all over this forum man, that's a pretty stone age setup for an evac system.
My next question was going to be why nobody uses the factory vacuum pump to draw fresh air through the system?
Oh and how is that ok to have an unfiltered way for sand and dust to get into the crank case when it's not running, lets say in one of those Arizona sand storms?
Old Apr 18, 2012 | 04:14 PM
Thundering6's Avatar
If your worried about sandstorms and dust blowing in AZ on a older 12v then all you need to do is add a aftermarket breather tank to the end of the crankcase vent.
The reason that no one uses a evac system is they are not needed for highway usage.There is a system made that the 5.9 Cummins equipped Case tractors use but most guys just buy the valve covers for added venting on their high HP 12v trucks and not the evac system.
Back years ago this is what was the rage on the TDR board with the 12v guys who did alot of towing,maybe this will help you..
Walker Engineering - Product Detail
chopperloco
Jul 10, 2016 10:45 PM
Ken in AZ
Mar 26, 2016 12:05 PM
The_W
Oct 28, 2015 09:00 PM
4B11T
Jul 13, 2015 03:48 PM
rojeho
Jul 12, 2015 06:10 PM
