wonder if the part dude at o'reilly is right?
Old Aug 3, 2011 | 09:23 PM
06murder's Avatar
Default wonder if the part dude at o'reilly is right?
well today i went to the part store right trying to find an fitting im need that noone has at all...anyways he tells me the carb that i have wont work with a return line its the carb with the barb in the front not the duel fitting like on double pumpers...can some tell what i need to do,or is the dude wrong? cuz im at the point to where im bout to just burn the damn truck to the ground n say da hell with it i have so much work done to it...i have no help sides on here...i put the motor in by myself ,and i weight like buck 20 if that! some opinion plz
Old Aug 4, 2011 | 04:23 PM
00buckshot's Avatar
I would put a double pumper on it if i were you, just sayin, you gonna race it anyways. I have a 750 dp holley hp on mine and love it!
Old Aug 4, 2011 | 04:26 PM
00buckshot's Avatar
Also, the carb has nothin to do with the return line, you need a return style regulator. you could come off the regulator and feed one single line into the front of the carb you have and use the return from the regulator to send excess fuel back!
Old Aug 4, 2011 | 04:37 PM
Mangled03gmc's Avatar
Baltimore Whore
What is this carb for??
Old Aug 4, 2011 | 05:15 PM
cttandy's Avatar
Yeah, I think we need some pictures of what your describing. Sounds like you have an edelbrock or old carter carb, but hard to tell. Take some pictures and explain what your trying to do, then maybe we can help.
Old Aug 4, 2011 | 06:26 PM
06murder's Avatar
its an holley 650...i got it for cheap from a buddy...it has the single barb fitting in front...
Old Aug 4, 2011 | 06:27 PM
06murder's Avatar
i have an holley returnble regulator....
Old Aug 4, 2011 | 06:37 PM
cttandy's Avatar
IF you have a return regulator, get a pressure guage to run inline after the regulator, hook the return line up off the regulator.
It I have done it before, works out well. This is how it looked on the truck I removed it from before the gauge broke. As you can see, the gauge is in line to the carb.
What it looked like on the truck, no pictures of the gauge on it. It looks backwards, since it wasn't mounted it wouldn't stay flipped around the correct way.
Old Aug 4, 2011 | 08:30 PM
06murder's Avatar
i have the same gauge n regulator but my has IN and OUT and RETURN on mine
Old Aug 4, 2011 | 08:32 PM
cttandy's Avatar
Mine did as well. I just got some adapters to connect it directly to my fuel lines. That is why it looks a little different.
