Syclone, Operation: "Quick Brick"
Old May 30, 2008 | 11:16 PM
  #41
AeroKing's Avatar
startup probably Sunday, then start tuning.
Old May 31, 2008 | 09:08 PM
  #42
AeroKing's Avatar
Old May 31, 2008 | 09:13 PM
  #43
7845's Avatar
Banned
looking good...but i think your air filter is going to be a huge restriction
Old May 31, 2008 | 10:09 PM
  #44
vanillagorilla's Avatar
Are you going to be running stock injectors? It looks like it in that pic.
I've been lurking on your build both here and syty.net since I find it interesting to see how fast you'll go. I find it interesting, because you're not doing the norm, like just going straight to vortecs/bowties, aftermarket hot parts, an 80E, or just a V8 swap. It seems like a nice budget build with parts that'll work well together.
Do you have any pics of the heads, and what port work was done to them?
Old Jun 1, 2008 | 08:24 AM
  #45
AeroKing's Avatar
30 over stock block, 4bolt splayed mains, h-beam rods, TRW pistons, stock crank, heads are L35 ported by Waller with 2.02 and 1.60 valves, 1.6 pro mag rockers, 875 lifters, pro mag pushrods, custom cam, 65# high imp injectors (would have needed 75 or 83, but i have meth so 65's are ok), AlkyControl meth injection, 72mm turbo from Precision, Code$59.
Old Jun 2, 2008 | 09:00 PM
  #46
AeroKing's Avatar
Old Jun 5, 2008 | 09:21 PM
  #47
AeroKing's Avatar
came extremely close to it running tonight.
had a bad ground wire, and the battery was grounding through the O2 sensors, and thin ground straps.
so i need to ground the engine a little better. it cranked fine, had no leaks, good fuel pressure, just a matter of better grounds.
Old Jun 5, 2008 | 09:33 PM
  #48
LIL QIK's Avatar
Looks like it's coming along nicely. Those damn grounds will get you everytime. People tell me that I over ground....I tell them not possible..lol. You're almost there.
Old Jun 7, 2008 | 09:42 PM
  #49
AeroKing's Avatar
http://media.putfile.com/Sy136--Startup
Old Jun 7, 2008 | 10:09 PM
  #50
SpoolinChevy's Avatar
Badass build. It sounds mean.
