My 1994 Suburban 5.3 Swap!
Old May 16, 2012 | 11:55 PM
RabidStreetRacer's Avatar
Originally Posted by BIGHAL
Adapter?? For What? Converter?
This crankshaft spacer is used when installing a transmission built before 1997 to a LS1-type motor. The LS design small block crankshaft flange is 10mm shorter in relation to the end of the bell housing flange. If using a small block automatic transmission built before 1997, there will be a 10mm gap between the crankshaft and torque converter when the bell housing is bolted to the block. This will require a flexplate spacer to adapt older small block automatic transmissions to the LS1-type engine. The LS1 flywheel is reused, and it goes on before the spacer. Torque converter bolt holes in the flywheel must be elongated to fit the non-LS1 torque converter bolt circle.
http://www.jegs.com/i/GM+Performance...63532/10002/-1
alex226
Jul 16, 2015 10:55 AM
06 4.8
Jul 15, 2015 07:17 PM
Ajaay
Jul 8, 2015 09:29 PM
mrgrim
Jul 8, 2015 08:12 AM
davis28905
Jul 8, 2015 03:20 AM
