LT4/8L90 '68 C10 Project
Old Dec 4, 2018 | 03:13 PM
Strictly Performance's Avatar
Former Vendor
adding more content
Last edited by Strictly Performance; Jan 24, 2019 at 03:08 PM. Reason: adding content
Old Dec 6, 2018 | 02:15 PM
BudRacing's Avatar
Great progress. I love how clean this build is--but then again you're not doing this on your backs in a small garage
Old Jan 25, 2019 | 09:26 AM
Former Vendor
[center]We just got the cab back from being media blasted and epoxied, and it was in sorry shape. We were told this was a southern truck but judging by all the rust it was from the salt belt. Although we were pretty overwhelmed buy the amount of work that was ahead of us, we dove right in and started sourcing as much reproduction sheet metal as possible. Unfortunately, every layer is not available for these trucks, so we had to custom make a lot. We are also shaving a lot of the excess holes and smoothing everything out that we can on the firewall. This update is almost exclusively body and metal fab related.
This hole is in one of the sections of
cab that don't have a reproduction part.
Rear window seal must have been leaking...
Under the rockers was in really rough shape. the rockers had been replaced before and looked like they were welded on by a
3 year old.
The floor pan and inner firewall were in bad shape, so we are replacing them
This is the lower a pillar where it meets the floor pan. there is a lot of work needed in this area...
Cab corner gone, and the
see thru floor pan
The passenger side floor pan was repaired at one point, notice all the rivets... we will be replacing the whole corner.
The inside of the
drivers[b] footwell was really bad. All the thin metal is being cut out and all new metal going in.
Old Jan 25, 2019 | 09:28 AM
Former Vendor
Test fitting the new floor pan on the frame before we mount it to the cab.
Why work at a performance
shopifyoucant have fun??
We braced the structure with tubing and the old rockers. Our tech, Daryl said it was his masterpiece "Roll cage"
Floor pan going in!
We had an interesting way to lift the cab, but it worked great and was totally safe.
Once the floor pan was mounted, we set the cab on the frame to take a look and make measurements to ensure everything was square.
This was our first glance at what it was going to look like.
Worktrucklol
25
Aug 1, 2018 08:36 PM
silverado78
Jun 5, 2018 06:07 PM
PSM
Jul 29, 2017 05:16 PM
r44guy
Sep 21, 2016 12:10 PM
gnasty1521
35
Nov 19, 2015 11:42 PM
