8l90 torque converter
Old May 30, 2017 | 04:34 PM
PSM's Avatar
PSM
Default 8l90 torque converter
My truck has developed​ the 8l90 tc shudder. Since my warranty is toast with the blower might as well upgrade right? I asked circle d and they make a 265mm that should stall stockish, but have a nice strong lockup clutch. Think I'm putting the cart before the horse if I install that tc and don't open up the trans? Does anyone know if there is enough tuning capability to compensate for that tc?
Old Jun 1, 2017 | 02:44 PM
Z71crawford's Avatar
id try warrenty first. The TC shudder was a recall. I had mine replaced at 3k miles
Old Jun 1, 2017 | 02:58 PM
PSM's Avatar
PSM
I debated that, but then I couldn't decide if I should be upfront with the blower or play dumb.
Old Jul 3, 2017 | 07:17 PM
EDawg's Avatar
There's is no recall on converters. You can have it fixed with a 3 stage flush and filter change. They should cover it under warranty. They know they have a issue w them.
Old Jul 3, 2017 | 10:37 PM
PSM's Avatar
PSM
They didn't that exact procedure and knew all about it and it worked! Unfortunately it wasn't warranty work because of the blower...
Old Jul 25, 2017 | 03:28 PM
Feed's Avatar
Ok dumb question, how do you get them to do the flush? They are denying there is a problem with my truck
Old Jul 29, 2017 | 05:16 PM
Feed's Avatar
Had a tech ride along today, so he could experience the shaking. You can hear the chatter and sort of see the vibration, tach needle is jumping around.
