long crank 6.0
None of these are correct. You need to buy a converter for a LT1/4l60e and run a flat flex plate from a older style SBC or if you get a 6 lug converter run a 99-00 2500 HD series. If you buy a converter for an LT1 and then buy a 5.3 truck down the road you can use the same converter/flex plate and a crank spacer on the LS cranks.
GreyChevy
Jul 7, 2015 08:57 PM
