lil.. help with getting my truck running
ok i went an try to turn it over right...(didnt check nothing cause cant move around that great right really sick) and i put the jumper box on the battery an the fuel pump was already pumping fuel be4 i had the key even in the ignition that was worried ??? but found the fuel leaks fix them while i was there there not leakin side the two in the firewall where i cant get to right now...but i try to c if it would turn but nothing....so can someone point me in the right direction plz
ok first off. U need to figure out the fuel situation, about the fuel pump running with the key off. Next, try turning motor over by hand make sure its not locked up. Thin check and see if u getting fire to the starter and other small details. Simple fix. Just take your time check over everything and look twice not once. Need anything give me a shout. Lil tipsy right now hope this all sounds right lol.
Nimoryan
Jul 5, 2015 03:50 PM
