clutch problems
Old Apr 13, 2011 | 09:18 AM
02 firechicken's Avatar
Default clutch problems
So I have a 88 c3500 pickup,with a 350 and a 4speed. The orignal problem was you put the truck in gear and it will not move. It will stay running with clutch pedal all the way up(won't stall). Its a hydraulic clutch,so I bled the clutch a lil. Now I could drive the truck,but I only got about 2 miles,then it started acting up again. Pump the clutch pedal a few times and it will drive.
So i replaced the slave cyl,clutch master cyl and the line. It took me a whole day to get this system to bleed. At one point I got the pedal to feel good and firm. But I could only get the pedal all the way to the floor once,and it was building pressure every time I tried to push the pedal down. It was like a brake pedal,WTF. So I bleed the clutch like your suppose to,there is no air in the system. So I took the slave cyl out and bleed the system from the slave cyl. Now the pedal is super soft 3/4 of the way down and feels like a clutch pedal form a 1/4 way from the floor.
Once again I bleed the clutch the way your suppose to and still dose the same thing. I would like to know,if I was right in thinking this problem was orginally a hydraulic problem. Also what is the problem now?
If you read all this thank you
madmann26
Apr 29, 2020 09:17 AM
Wolftrk99
Dec 3, 2015 08:12 PM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
