chevy 73 thru 87 ls swap headers for 4x4
Old Jul 15, 2013 | 01:08 AM
chevy1978's Avatar
Wink chevy 73 thru 87 ls swap headers for 4x4
ok so i know theres alot of forums on here that talk about ls swap headers for our year trucks 73 thur 87 but has anyone had a success with any longtube tube headers on there 4x4 if so what brand and how much did you have to do to make them fit
Old Jul 15, 2013 | 01:10 AM
chevy1978's Avatar
i ment to put 87
Old Jul 15, 2013 | 07:37 PM
smoggist's Avatar
In for some info as well!
Old Jul 15, 2013 | 08:15 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Talking
Originally Posted by chevy1978
i ment to put 87
Fixed for you!
Old Jul 16, 2013 | 12:17 AM
chevy1978's Avatar
some guy on youtube has a 85 chevy long bed with a 5.3 and he said he used 2010 ss camaro longtube headers but had to cut the collecters and re-weld them to clear the front driveshaft if thats all its not to bad but he didnt say what brand he used theres a video on it look at it its called ls swap in a chevy k10 its a silver and blue longbed chevy
Old Aug 9, 2013 | 06:37 AM
85SILVER's Avatar
Default 85 c10 5.3l headers
I have a 85 c10 that i have put a 5.3l in. I raised the engine up 1 inch higher than normal and i took 98 camaro long tube headers and had them cut and rerouted to miss the frame and crossmember. I also had to grind the a frame on the drivers side top of the bushing to clear them and had to cut 1 inch of the passenger frame from the mount to cross member to clear. Now they make ls headers for the ls swap from lmc truck, but they are costly.
Old Aug 9, 2013 | 07:59 AM
bstill's Avatar
I used Schoenfeld ls1 truck headers. Made for swaps.
Old Aug 26, 2013 | 08:58 AM
goinbrokez28's Avatar
Are you 4x4? Only LT's on there site are for 2WD that I've seen for square body's.
I have a cammed 5.3 to drop in mine and really dont want to use cast manifolds.
Old Aug 26, 2013 | 09:09 AM
Just found this...
LQ4 swap into 84K5 - CK5 Forums
p/n 1302LS1 on Schoenfield's site.
I am gonna go this route, hopefully this helps someone else too.
Old Aug 26, 2013 | 07:57 PM
smoggist's Avatar
He's lifted 8 inches. That's gonna help out with the drive shaft clearance some.
