Another 5.3 into an '85 C10
Old 12-30-2009, 10:08 PM
12 Second Club
Default Another 5.3 into an '85 C10
Well , here I go again I have already installed an LS moter in a '79 C10 and started to put an LS motor in a '65 Chavelle. This time I am putting a 5.3 out of a '03 GMC Seirra into my daily driver '85 short bed Chevy C10. Here are some details on the motor....
I started off with a complete 5.3 pull out, disassembled it, left the bottom end alone, freshened it up with a new timing chain and an oil pump. I put a low mile Z06 Cam in it, and a set of ported (by Chris Mitchell) milled, and cut for bigger valve 5.3 heads.
The truck is my daily driver so I am hoping to get it back on the road ASAP!
I am hoping to pull the old 350 this week end so I can get started with the install. Thanks for looking.
Old 12-30-2009, 11:37 PM
LS ADDICT/BUILDER
montecarloss's Avatar
nice truck and good luck on the project
Old 01-09-2010, 11:00 PM
12 Second Club
been busy today. i started unhooking things last night.
this morning i pulled the 350/350th out.
im going to clean up the engine bay tonight. heres the empty hole...
i seperated the old combo and reinstalled the 350turbo on to the 5.3 today also. im going to try to have the motor sitting in its new home by the end of tomorrow!
Old 01-10-2010, 04:25 AM
lechez71's Avatar
making good progress, keep it up. what are you going to do about A/C?
Old 01-10-2010, 07:39 AM
12 Second Club
i havent decided yet. i dont know if i can use any of the existing a/c or not. i need to do more research
Old 01-11-2010, 04:01 AM
lechez71's Avatar
when i put the 5.3L in my 82 c10, the A/C comp would hit the frame rail. theres someone on this site that fabs A/C brackets to relocate the compressor to the top. let me try and find a link for it.
Old 01-11-2010, 12:48 PM
370 RAM AIR's Avatar
What type of wiring harness are you gonna use
Old 01-13-2010, 07:07 PM
12 Second Club
im going to reuse the 5.3 harness.
Old 01-14-2010, 11:44 PM
12 Second Club
all right, i finally got the motor/trans shoved into the truck tonight. for mounting i am using ls to smallblock adaptors with the original clamshell truck mounts. i am reusing the th350 mount. i moved the motor mounts up a 1/4" to compensate for the adaptor plates. looks like im gonna have to move the crossmember forward an inch. i checked the driveshaft and still have plenty of engagement. here are some pics....
Old 01-16-2010, 11:18 PM
12 Second Club
well today, i reinstalled the fuel tank, ran new fuel lines, installed new fuelpump and filter, fitted and welded out the exhaust. i plan on tackling the wiring tomorrow.
Quick Reply: Another 5.3 into an '85 C10
