96' reg. cab 5.7L vortec
Old May 11, 2007 | 05:36 PM
Chevy96's Avatar
Default 96' reg. cab 5.7L vortec
hey guys whats going on well i got a few question on whats the best bang for the buck performance out there for me
Old May 12, 2007 | 12:29 AM
YenkoST's Avatar
The best bang for the buck is: Long tube headers(Hooker makes a set), dual 2 1/2" exhaust from the collectors back routed however you want, custom tune(Nelson can do it since you are in Texas or do it yourself), Electric fans, depending on what gears you have some 3.73s or 4.10s might be in order, CAI(homemade or K&N), and an all around tune up(spark plugs, wires, fuel filter, changing oil/tranny/rear fuild, distrib. cap and rotor button). If you want to clean the engine out a little bit, put some seafoam in the oil for about 100 miles and drain it and also you can put some in your fuel to clean your injectors.
Old May 15, 2007 | 10:34 PM
ThrottleHappy7's Avatar
Intake and exhaust are probably the best bang for the buck, and they're something that will help your truck out, not just hp/tq but also gas mileage... depending on how you drive.
That's where I'd start, and then go from there. Also, what are your ideas for the truck?
Old May 16, 2007 | 03:44 PM
Chevy96's Avatar
yeah been looking into getting some but i cant find any with the o2 sensor but you said that hooker makes a set ill look into but thatnks for the help guys, but what ive done is a engine tune up ( new spark plugs, wires, fuel filter, drop in k&n filter) cat back dual exhaust, and 3.73's.
Old May 16, 2007 | 07:17 PM
YenkoST's Avatar
For your rear o2s, if you delete the cats, you will need a tune to turn them off. For your others, since they are heated, you can stick them about anywhere as long as they are close to the header.
Old May 18, 2007 | 04:38 PM
Chevy96's Avatar
if i delete the cats will it pass emissions
Old May 18, 2007 | 05:34 PM
Gran Patron's Avatar
Yes, as long as if you dont have a S.E.S light on or had one just recently cleared when ever you do your emissions test.
Old May 18, 2007 | 08:54 PM
YenkoST's Avatar
Depends how strict Texas is....if they look under your truck then your going to fail.
gaps
Oct 15, 2015 02:53 PM
projectnightcrawler
Sep 30, 2015 10:49 PM
abey15
Sep 25, 2015 09:30 PM
FlowmasterMufflers
Sep 11, 2015 03:32 PM
2004gibbstruck
Sep 7, 2015 06:05 PM
