95 engine into 89 silverado
Old Nov 20, 2012 | 10:35 AM
shortwide95's Avatar
Default 95 engine into 89 silverado
I have a 1995 chevy silverado thats on its last legs. Its 2wd has a 350 and an automatic transmission. I have a chance to pickup a 1989 chevy swb 4x4. It has the transmission and the transfer case along with all of the wiring it just needs a motor. I was told that in 1995 they have obd2 instead of obd1 and was wondering what all i would need to swap over from an 1989-1994 engine to the 1995 350 to fit right into the 1989 chevy? Thank you
Old Nov 20, 2012 | 12:23 PM
1994Vmax's Avatar
The 95 is a drop in. 96 was the switch to OBD 2 and the CSFI Vortec engines. 95 is still a toilet bowl injected turd like the 89. The only difference wiring wise will be the throttle body itself as the 95 will have a different throttle position sensor than the 89.... but you can just swap the plugs since you have the 95 to cut it off of. The 95's TBI also will not have the linkage to hook up the TV cable on the 700R4 that is no doubt in the 89. But that is pick and pull junkyard stuff. Otherwise its a simple swap. Most missing pieces if anything can be salvaged off your 95.
Old Nov 20, 2012 | 03:47 PM
Default Tbi
So i can just get a tbi off of an 89-94 chevy pickup and just bolt and go? I will eventualy go either carbed or mpfi but at the moment i just want it running so i can drive it around . I also dont want to do any wiring right now hence the plug/bolt and go thing im after.
Old Nov 20, 2012 | 04:01 PM
1994Vmax's Avatar
No not really. 93 and 94 1/2 tons are 4L60E's as well so the same as 1995. Up through 1991 had the old style throttle position sensor and if so equipped would have the 700r4 linkage. 1992 does as well but has the new style round throttle position sensor like your 95. There are exceptions but that is a loose guide to use. Any 4.3/5.0/5.7 throttle body base is the same as well making your search a bit easier. You can just swap your 95's injector pod on whatever you buy to keep the correct injector size.
Old Nov 21, 2012 | 06:01 PM
Default so...
So what your saying is i need a 1989-1991 tbi in order for it to be bolt in? As in i can take the tbi off of one of those year trucks switch it with mine and it wil bolt in and all linkages will hook up? sorry for being a newb at this im not used to tbi's.
Old Nov 21, 2012 | 06:06 PM
1994Vmax's Avatar
1987-1991 throttle bodies from a truck with a 700R4 is all you need.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
chopperloco
Jul 10, 2016 10:45 PM
Ketis
Jul 23, 2015 12:37 PM
85SS/85GN
Jul 22, 2015 12:48 PM
Mark_k
Jul 9, 2015 12:37 AM
