5.3/4L60 swap into a 1993 SWB questions
Old Sep 12, 2016 | 11:55 AM
2000_SS's Avatar
Default 5.3/4L60 swap into a 1993 SWB questions
Got the engine and trans in, need to know how to connect the stock shifter linkage to the 4l60e, or if I need to order something aftermarket...used to be a 305/700R4....also what oem throttle cable works with this swap, if any? I've heard 96-98 Silverado cables will work.
Old Sep 12, 2016 | 12:04 PM
akdg87's Avatar
take the shift linkage off the 700R4 (although it should be a 4L60E for a 1993 pickup)and install it on the newer trans, i had to adjust mine a little bit but it was pretty close.
96-98 vortec throttle cable works great.
Old Sep 19, 2016 | 02:27 PM
2000_SS's Avatar
Got the old shift linkage in. It doesn't want to work at all. It acts like it's in a bind no matter how I adjust it. How did you adjust yours to make it work?
2FNQUIK
Aug 22, 2016 04:55 PM
Schiavonske1013
Aug 15, 2016 11:09 AM
2FNQUIK
Aug 4, 2016 10:29 PM
OldPainless
Jul 30, 2016 10:18 AM
Kike817
Jul 21, 2016 10:36 AM
