5.3/4L60 swap into a 1993 SWB questions
Got the engine and trans in, need to know how to connect the stock shifter linkage to the 4l60e, or if I need to order something aftermarket...used to be a 305/700R4....also what oem throttle cable works with this swap, if any? I've heard 96-98 Silverado cables will work.
take the shift linkage off the 700R4 (although it should be a 4L60E for a 1993 pickup)and install it on the newer trans, i had to adjust mine a little bit but it was pretty close.
96-98 vortec throttle cable works great.
Schiavonske1013
Aug 15, 2016 11:09 AM
OldPainless
Jul 30, 2016 10:18 AM
Kike817
Jul 21, 2016 10:36 AM
