KC people
#241
Indeed.
I think my brother will actually help me out and let me do that at his shop. Snow sucks! I had my NT05's on and drove it across Manhattan sideways just barely off idle so I could get home the other night. lol
Two recent videos of turd truck, I have caltracs finally.
Colorado with Caltracs - YouTube
Colorado with Caltracs and A/T's - YouTube
#244
Here is pretty much everything I bought, it adds up quickly.
Turbo
Hot Pipes
Cold Pipes
Couplers
Clamps
Intercooler
Waste Gate
Blow Off Valve
Oil Feed
Drain Feed
Wide Band Gauge
Boost/Vacuum Gauge
Fuel Pressure Gauge
Injectors
Gauge Mount
Boost Controller
Spark Plug Wire Boots
Spark Plugs
Exhaust Wrap
Oil Supply Adapter
Turbo Blanket
Fuel Rail Adapter Fitting
Vacuum Distribution Block
Mike Norris Catch Can
High Temp Exhaust Paint
Tune
E85 Fuel Pump
4l80e Transmission
Shift Kit
Circle D 4l80e 3200 Converter
I still need some fittings for my trans, a drive shaft, and a Detroit TruTrac for the rear.
Have fun!
Turbo
Hot Pipes
Cold Pipes
Couplers
Clamps
Intercooler
Waste Gate
Blow Off Valve
Oil Feed
Drain Feed
Wide Band Gauge
Boost/Vacuum Gauge
Fuel Pressure Gauge
Injectors
Gauge Mount
Boost Controller
Spark Plugs
Exhaust Wrap
Oil Supply Adapter
Turbo Blanket
Tune
E85 Fuel Pump
4l80e Transmission
Shift Kit
Have fun!
#247
I'm thinking:
LS9 headgaskets
ARP headstuds
katech rod bolts
ZR1 cam
GT45
flipped truck manifold on passenger side and keeping longtube on driver side?
interfooler
91 octane
new fuel lines
will walbro 255 be enough?
LS9 headgaskets
ARP headstuds
katech rod bolts
ZR1 cam
GT45
interfooler
91 octane
new fuel lines
#248
Ive been debating a rear mount with the gt45 turbo I could piece together a setup with intercooler for about 1400 with tune and a long weekend. But still learning on what size to get ger seeing different varations
#249
