Central & Northern ND, SD, NE, KS, OK, MN, IL, MO, IA, KY, OH, IN, MI, WI
KC people
Old Mar 25, 2013 | 05:52 PM
  #241
slammedsilvy's Avatar
Originally Posted by 07redgmc
Thanks it's not bad.. I'm putting together a turbo build so I'm up for any tips if y'all have done turbo builds
I learned a thing or two about turbos putting one on mine.
Originally Posted by Area47
and a fuel pump
Indeed. I think my brother will actually help me out and let me do that at his shop.
Originally Posted by Slammed96
New trans should be in tomorrow! Hopefully have it in and done by the end of the week.
Just need this stupid snow to go away so I can try it out along with my new stall.
You and I are both anxious to try out our new trans and stalls.
Originally Posted by Karlen
Snow sucks! I had my NT05's on and drove it across Manhattan sideways just barely off idle so I could get home the other night. lol
Two recent videos of turd truck, I have caltracs finally.
Colorado with Caltracs - YouTube
Colorado with Caltracs and A/T's - YouTube
Nice videos!
Old Mar 25, 2013 | 08:13 PM
  #242
07redgmc's Avatar
well im ordering one from kb with the pt76 i know ill need injectors and fuel pump when the trannys goes it will be getting a 80e im not sure what else ill need.
Old Mar 25, 2013 | 08:22 PM
  #243
JoeyGC5's Avatar
I just wish I could get my truck or the Vette outta the garage. Flurries and snow oiled up everywhere sucks
I'm up for another meet and greet.
Old Mar 25, 2013 | 08:26 PM
  #244
Here is pretty much everything I bought, it adds up quickly.
Turbo
Hot Pipes
Cold Pipes
Couplers
Clamps
Intercooler
Waste Gate
Blow Off Valve
Oil Feed
Drain Feed
Wide Band Gauge
Boost/Vacuum Gauge
Fuel Pressure Gauge
Injectors
Gauge Mount
Boost Controller
Spark Plug Wire Boots
Spark Plugs
Exhaust Wrap
Oil Supply Adapter
Turbo Blanket
Fuel Rail Adapter Fitting
Vacuum Distribution Block
Mike Norris Catch Can
High Temp Exhaust Paint
Tune
E85 Fuel Pump
4l80e Transmission
Shift Kit
Circle D 4l80e 3200 Converter
I still need some fittings for my trans, a drive shaft, and a Detroit TruTrac for the rear.
Have fun!
Old Mar 25, 2013 | 09:31 PM
  #245
07redgmc's Avatar
sweet i had everything on my list but the catch can not sure what that is but ill look it up and get one
Old Mar 25, 2013 | 09:32 PM
  #246
07redgmc's Avatar
did you put head studs in before the turbo?
Old Mar 25, 2013 | 10:21 PM
  #247
Karlen's Avatar
I'm thinking:
LS9 headgaskets
ARP headstuds
katech rod bolts
ZR1 cam
GT45
flipped truck manifold on passenger side and keeping longtube on driver side?
interfooler
91 octane
new fuel lines
will walbro 255 be enough?
Old Mar 25, 2013 | 10:48 PM
  #248
2000chevysilverado's Avatar
I'm thinking:
LS9 headgaskets
ARP headstuds
katech rod bolts
ZR1 cam
GT45
interfooler
91 octane
new fuel lines
Ive been debating a rear mount with the gt45 turbo I could piece together a setup with intercooler for about 1400 with tune and a long weekend. But still learning on what size to get ger seeing different varations
Old Mar 25, 2013 | 11:47 PM
  #249
I'm still on factory bolts. I'm on low psi right now, that will soon change. I'll likely pull the trigger on a cam, springs, lifters, push rods, timing chain, head studs, and ls9 gaskets sometime late spring/summer.
Old Mar 26, 2013 | 12:58 AM
  #250
07redgmc's Avatar
I've already done all that but I didn't put in head studs i put bolts back in.
