4.8 to 5.3 swap
Registered User
4.8 to 5.3 swap
Anyone in the Louisville,Ky area thats good with 5.3 swaps? Im putting a Ly5 into a 2002 Silverado 1500 that had a 4.8. Im having issues with the wiring, anybody willing to offer advice? Im dumb as hell when it comes to this stuff!
There are conversion harnesses for everything. I don't know, but you might be able get a harness from a newer truck with the correct plugs on it. The crank has a different reluctor wheel, I know there is something that converts the signal, but it might be easier/cheaper to get a newer computer that will work. You might want to put this in another section, because the crank reluctor wheel stuff, is a total guess.
Cam sensor conversion
EFI Connection, LLC - Item Details
Knock sensor conversion harness
You will have to find out about the 24-52 tooth crank sensor.
