new track times...... about right to you?
Old Feb 12, 2006 | 10:44 PM
Default new track times...... about right to you?
The first pass I made was with the 50hp tune, and head light removed and the tail gate down(i took the tonneau off to clean it)... it was a 16.36@83 mph with a 2.08 60'(tha phucked is straight up fast outa the gate).
then I changed nothing but put the 100hp tune in and ran a 16.26@ 77 mph. I can't figure out where the problem is here. The tranny doesn't seem to be slipping. But it did cut a 1.998 60'!!!!!
The tranny temp did get up a little(about 200 degrees)b/c the guy in the tower phucked me all up by resetting the lights about 4 times... this was on the first pass.
I hope its the damned programmer just not working worth a ****!!!! But either way I'm staying away from the track for a while!
Josh S.
Old Feb 13, 2006 | 05:54 AM
1bad01dmax's Avatar
Those times are horrible. A stock truck can run those times. What programmer do you have?
Old Feb 13, 2006 | 09:45 PM
its a power pup
Old Feb 13, 2006 | 10:52 PM
Bad_Apple's Avatar
I know are 03 3500 CCLB Dually with 90gal. fuel tank/toolbox. It has a chip I was running 9:40's @ 75mph. in the 1/8 I was having bad traction issues having 2.2-2.3 60ft. times. I only have 100 h.p. chip, CAI. Your times seem bad off are you sure you programmer is plugged in properly. If not give Bully Dog a call and tell them your pup is sick.
Old Feb 15, 2006 | 02:18 PM
BMDMAX's Avatar
Josh S.
Your 60 foot times look good so either you are having a fuel issue or trans issue. No codes? Either one should make the truck go limp on ya. Sounds like you are getting some slip in the trans with the extra heat you were seeing.
madmann26
Apr 29, 2020 09:17 AM
AdaMax
May 16, 2016 11:35 PM
Vortec350ss
Jan 12, 2016 10:36 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Slammed silverado
Sep 28, 2015 06:14 PM
