is my truck lifted?
Old Nov 9, 2010 | 08:21 PM
05rado's Avatar
and for some reason your truck has one more leaf in the back than mine? i thought all hd's had 4 and a helper leaf yours has 6 total.
Old Nov 9, 2010 | 08:25 PM
dlt76028's Avatar
i would get rid of those rims for sure.
Old Nov 9, 2010 | 09:38 PM
1BAD_LS1's Avatar
Restricted User
Originally Posted by 05rado
looks like it used to be an old rail road truck, they have those rims. my truck is is basically the same truck and is lifted 3in and i can only fit up tp 315s and thats with a little more clearance with a ranch hand bumper
you got it! it was a UP hi-rail truck... the truck was modified to carry the tack wheels and the wheels/tires were set in to run down the track. This truck spent its life runing down the track at 30-45mph all its life lol.
Old Nov 9, 2010 | 09:41 PM
1BAD_LS1's Avatar
Restricted User
ya lol they make me wanna
ive only had the pickup for a week... and have been searching ever since to find wheels/tires.
Im so confused on what back spacing, offset, and width to get... i pretty set on 17" wheels just unsure on the rest of it.
as for tires i obviously wanna go as big as i can without rubbing issues.... the current tires rub on the swaybar a little when turning really sharp (as you can imagine since they sit in so far lol)
Old Nov 10, 2010 | 09:39 AM
dlt76028's Avatar
for a 17 go with something like a 295/70/17 or 305/70/17. Heres a good website to check tires sizes.
http://www.discounttire.com/dtcs/infoTireMath.dos
Old Nov 11, 2010 | 02:01 AM
bighoss77's Avatar
its an HD, it has a bigger leaf pack and the frame is 2" taller than a regular 1500/2500... so basically if you want to get technical it has a 2" "body lift" becuase the body mounts are higher up on the frame. you will not be able to clear 35's... 33's will clear if your wheels dont have alot of offset.
Old Nov 12, 2010 | 10:05 AM
Dgrown's Avatar
sits higher in the front then my truck but has the same amount of leafs in the back
Old Nov 12, 2010 | 10:23 AM
1BAD_LS1's Avatar
Restricted User
Thanks guys! I'm gonna try to fit some H2 wheels with 315 70 17 tires on it!
Old Nov 12, 2010 | 05:38 PM
05rado's Avatar
mines a 05 2500hd and
has one less leaf...............
Old Nov 12, 2010 | 07:28 PM
dlt76028's Avatar
that should look good.
