is my truck lifted?
Restricted User
is my truck lifted?
05 Silverado 2500HD 4x4 6.0 4l80e, was a company truck... i am wondering if it is lifted, as it seems to sit pretty high... check pics.
what do you guys think? Im in the process of looking for the rims/tires to buy... thinking i might be able to go with a 35" tire! the current tires on it are 225 70 19.5 (~31.5" tire) with room to spare...
Havent had time to do anything with it yet since i have only had it a week. New wheels/tires and new bumpers are first on the list! It needs a little TLC but will be a nice truck when its done
I think it has added leafs... and possibly a larger block?
they look cranked up a good bit dont they????
Location: as far away from Koonerville as humanly possible
Hmm, what is up with the dually style wheel/hub? Never seen that on a 2500HD before.
Does it have dual rear wheels?
And yeah, my truck only has 5 leafs.
Restricted User
They are aspecial 19.5" rim designed to offset the wheeltire to the inside... also has hub spacers that bolt to stock hub and changed the patern.
Seems to sit pretty high
Restricted User
I have 3 1/4" between the bottom far corner of the front bumper (metal part) to the tire...
3 1/4" between the bottom far corner of the fender flare (cab side) to the tire...
so how much bigger you guys think i can go??? the current tire is 32"...
I assume when the steering wheel is turned it will stick out farther than when the wheel is straight (edges of tire when steering wheel turned)....... how do i calculate for how far the edge of the tire will go when turned compared to when it is straight????"
looks like it used to be an old rail road truck, they have those rims. my truck is is basically the same truck and is lifted 3in and i can only fit up tp 315s and thats with a little more clearance with a ranch hand bumper
