Labor cost
Old Jun 23, 2017 | 11:27 AM
riverhawk's Avatar
Default Labor cost
How much should labor cost to install a cam and valve springs, collars, keepers, valve seals and pushrods? I have all the parts already.
Old Jun 23, 2017 | 02:56 PM
About20ninj45's Avatar
80 dollars an hour times 4+ hours it's my guess
Old Jun 23, 2017 | 03:07 PM
FFDP's Avatar
Depend on who you take it too.
Most shops will charge labor based on the parts they have to remove. Using Mitchel to get a labor quote it's 21 hours of total labor to do a full cam swap. That includes removing both cylinders heads, lifters, front cover, timing chain/pump, cam gear and camshaft. Doing the cylinder head work itself is another labor time if going by a book.
A performance shop likely won't charge that much because some steps would be skipped in the labor book. $1,000-1,500 is just a guess.
Old Jun 23, 2017 | 05:53 PM
riverhawk's Avatar
I was quoted 1200.00 to 1600.00 today from total performance in Augusta, GA. I think 600.00 to 800.00 would be fair. So I guess I'm going to do it myself.
Old Jun 24, 2017 | 11:07 AM
stealthperf's Avatar
I installed my own and it's really not that bad... More time consuming than anything.... I removed the spark plugs and used compressed air to hold the valves in while changing springs and seals.. Also, get something like this spring compressor. They work pretty slick.
Old Jun 24, 2017 | 07:02 PM
madmann26's Avatar
On my old 5.3 engine, can, springs and a torque run me less than $600 labor.
1. Cam can be out in 30min.
2. Trans can be out in 30-40min (assuming you have a lift)
3. Springs can be done in a couple of hours.
It really isn't that hard. A cam only swap can be done in 90min.
Old Jun 26, 2017 | 04:21 AM
riverhawk's Avatar
Thank you for the replies
